Results 1 to 3 of 3
Thread: Help Car Will Not Start after Flash
    Mar 2015
    Default Help Car Will Not Start after Flash
    I have a 2013 Camaro ZL1 and purchased a 650hp upgrade kit from Lingenfelter.
    This included an Autocal and tune. I followed the instructions, read my stock tune to the Autocal, and flashed the supplied tune. Now the car will not start.
    It is a manual and the DIC says depress clutch to start. When I depress the clutch it makes no difference. I was no where near the gearbox when installing the upgrade kit, nor was I under the dash at all.
    I looked at all the PID's and there is one called CPPV which I am guessing is clutch pedal position voltage. It reads zero regardless of where the clutch pedal is located, depressed or not. I am guessing the car does not know that I have the clutch pedal depressed.
    I have tried to contact LPE but no luck yet. I am located in Australia so have VERY LIMITED SUPPORT here so am relying on remote support.
    Please help, I have an expensive car that's a boat anchor at the moment.
    Thanks,
    Terry
    Hi Terry, a ZL1 in Aus is a rare thing indeed. Looking at the time you first posted you may have been in contact with LPE already, let us know how you get on. I'm not sure what could have gone wrong though.
    Lifetime Member limited cv8r's Avatar
    May 2005
    Im not exactly sure how the autocal works,but can you flash your original tune back into car to verify if it will start/run on that. If it will then you know the problem is with the supplied tune and not the autocal.
  1. Trailbalzer red the file but refused to flash and the car won't start again
    By odd boy in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: October 29th, 2011, 01:59 PM
  2. Car wont' start, need some help!
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 10:08 PM
  3. New RR wont start the car
    By ntae in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 18th, 2007, 08:45 PM
  4. car wont start with COS#5
    By articSS in forum Custom Operating Systems
    Last Post: September 19th, 2007, 12:43 PM
  5. Getting a camed car to idle at start
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 7th, 2005, 10:12 AM
