Results 1 to 10 of 10
Thread: Speedo Calc, LS1 Corvette
    Jun 2014
    Default Speedo Calc, LS1 Corvette
    I've read a few threads on the speedo calc but I still don't get it.
    The car is a 2000 LS1 Corvette with manual transmission and 3.42 differential (H0103).
    Stock rear tire = 275-40-18. When I plug that into the calculator it comes up with:
    H0101 = 18802 (edit: fixed previous number what was in the wrong units)
    H0102 = 11.70
    When reading the stock tune it shows:
    H0101 = 19280
    H0102 = 40
    My current dyno tune shows:
    H0101 = 19884
    H0102 = 40
    Are these just minor tweaks to fine tune the speedo? The dyno tune is off the stock tune by over 5%. I'm thinking the tuner just copied / pasted from another cars tune and missed that the other car had different size tires.
    I'm changing the rear tires to 305-35-18, the calculator indicates:
    H0101 = 18984
    H0102 = 40
    Should I just start with 18984 and adjust according to my GPS at highway speed?
    What is the calculation performed by the calculator?
    Thanks!
    Is the Transaxle checkbox checkmarked...?
    Post your tune file.
    Mar 2007
    FWIW - I've played with the speedo calculations on the full sized trucks. From what I have found, yes, the factory "tweaks" the cal to get the speedometer to read right. I did the hand calculations, and compared it to what was in the stock files from the factory. Yup, GM tweaks them to get the right .
    Jun 2014
    Joecar, yes the box is checked!
    Turbo_bu, thanks. Guess I'll go with the calculator value for the new tires and adjust according to my GPS. What is the calculation?
    Rob
    Mar 2007
    Example of what is calculated:
    {H0101} Vehicle Speed Sensor Pulses per Kilometer 62763 Pulses/Km
    {H0102} Vehicle Speed Sensor Pulses per Revolution 40 Pulses/Rev
    {H0103} Differential ratio 3.71997 :1
    {H0101} is calculated using the following formula:
    tire size (T), H0102 (P) and H0103 (D) using the equation:
    Pulses per mile: H0101=P*D*63360/(T*pi) where T is specified in inches.
    Pulses per km: H0101=P*D*1000000/(T*pi) where T is specified in mm.
    If you start plugging in your numbers you will probably see what the "theoretical" value is ... and what the actual factory value is.
    Jun 2014
    I must be doing something wrong.
    T = Tire diameter (inches)
    305-35-18 = 26.41"
    T*pi = circumference = 82.96"
    63360 = inches / mile
    D = H0103 = Differential ratio = 3.42
    P = H0102 = Pulses per rev = 40
    H0101 = 40*3.42*63360/82.96 = ~104480 (calculator shows 18984)
    Mar 2007
    Not exactly sure, but seem to remember that under the Speedo Calculator there is a check box for Corvettes. The pop-up info for the check box says that the pickup is on the axle and not the transmission output. Guessing that this might be part of the issue??? I have not played with corvettes yet, mainly trucks, Camaro's and swaps.
    Dec 2006
    When measuring your tire diameter it also makes a difference on the width of the rim. The 26.4" diameter for your tire is measured on a 12" wide rim. If you have hoosiers/kuhmo autocross tires on 10.5" wheels they will be a slightly larger diameter. The Corvette PCM will make the corrections based on axle rotation. I have changed tire sizes on both my Escalade and Corvette and the GPS shows the spedo to be very close to its reading based on 10 mile runs.
    Jun 2014
    Turbo_bu, Joecar had asked about the checkbox and it is checked. It looks like when it is checked the calculator uses an H0102 of 11.7 (instead of 40). When I use that and calculate by hand (spreadsheet), I get close to the same result as the calculator. Curious why it isn't exact. I'm not rounding off and I'd expect the calculator isn't either.
    I noticed that I made a mistake in post 1. I gave pulses / km from the calculator and pulses / mile from the tune. They are now both in pulses / Km and not that far off.
    OEM Tune = 19280
    Calculator = 18802
    Difference = 2.5% probably due to GM tweaking for the actual tire rather than calculated values.
    Calculated by hand = 18808, fairly close to the calculator.
    Rob
  1. delete corvette LS1 DBW
    By stairman in forum Conversions / Aftermarket Parts
    Last Post: February 14th, 2015, 12:30 AM
  2. Corvette C4, LS1 P1SC Procharger need tune
    By legendvette in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 8th, 2010, 04:04 PM
  3. Problems with Speedo Calc. / PLEASE HELP
    By Boost in forum E37, E38 & E67 PFI ECM's
    Last Post: April 17th, 2008, 11:17 PM
  4. New update - speedo calc. still funky
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 25th, 2008, 08:14 AM
  5. 1998 Corvette LS1 VATS problem
    By Rewire in forum Gen III V8 Specific
    Last Post: September 12th, 2007, 10:36 PM
