Where can I see what OS are available. I have an 04 C5 I am working on and would like to know what my options are. I am thinking I am going to need to convert the car to Alpha N and was curious if this was available for the LS1B.
Justin
Justin
I had seen that, but thanks. What about Alpha N is that available?
It's not shown in that tutorial but COS 5 has a TPS VE table (A0007), its not Alpa N as in MAP and TPS , table A0007 is RPM and TPS.
There are also options from A0003 to A0006 to control when this table is used or not.
Hope this helps
alpha-N is TPS (alpha) vs rpm (N).
COS5 has an alpha-N VE table (TPS VE table).
Read thru this COS5 summary: COS5.txt
yep,my mistake. I confused Alpha-n with speed density, doh
