Results 1 to 5 of 5
Thread: 06FF Checksum Failure on E38 PCM for 06 Z06
    Default 06FF Checksum Failure on E38 PCM for 06 Z06
    I recently had to change PCM's in a 2006 Z06. I have updated my Flashscan and software to the latest version and revs. I continue to get the 06FF Checksum failure message after several attempts to flash the controller. I have attached t2006 Z06 PCA Tune_E38_0002.ctzhe file I am using. Any help would be greatly appreciated. Thank you.
    I have been able to perform a full flash of the controller with a different file. I have also been able to flash the PCM with the stock GM calibration file using my GM MDI interface. Looks like my attached file may be the issue. Any advice?
    Looks like another programmer had been on there before, one of them does something to the tunes that makes EFILive think the checksums were wrong at the end of the flash, try the attached 'fixed' version of that tune.
    Thank you for the reply.
    Looks like my software version will not open the file. I am running 8.2.2.258 Build 258.
    What version are you on?
    I just downloaded the March update and was able to open it. I will give it a try and let you know.
  1. E38 Camaro Checksum failure
    By horst in forum E37, E38 & E67 PFI ECM's
    Last Post: March 13th, 2015, 02:23 AM
  2. Checksum error code $06FF with L92 PCM
    By 67SS509 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: December 5th, 2014, 02:51 PM
  3. T43 TCM code $06FF: checksum failure
    By 400ss in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 15th, 2014, 10:26 AM
  4. Replies: 2
    Last Post: July 17th, 2012, 04:27 PM
