Results 1 to 7 of 7
Thread: Weird Throttle CrackerIssue
    Jan 2015
    Default Weird Throttle CrackerIssue
    Hi, I am having this weird issue where My truck will have the cruise control effect. I have zeroed out the throttle cracker values from 400 to 1600 RPM's, while monitoring the Throttle Cracker in the scan tool, the moment TC is activated (via the speed threshold), I see Values ( anywheres from 0.12 to 0.38) g/s coming from the TC pid, I am commanding 0 so where and what is commanding these values? I've been trying to figure it out now for over a week and have reached my limit!
    Jan 2014
    look at throttle follower.
    Jan 2015
    The follower remains at 0 g/s according to the scan tool, which it should be as I am not even touching the throttle. If I get off the brake after a stand still, it slowly accelerates and once it reaches the TC speed threshold (5km/h) you can feel the truck accelerate even more, it will reach about 27km/h on it's own. I increased the speed threshold to 15 km/h and now it will climb up to about 8km/h since the TC remains at 0g/s. Which again does not make sense since I zeroed out the TC values between 400 and 1600 RPM.
    Jan 2014
    I see. I thought you were slowly getting on the TPS.
    Jan 2015
    I did also disable rolling idle and that did help but somehow it still accelerates on it's own!
    Jan 2014
    Have you compared the tune to stock?
    Jan 2015
    I would like to compare my tune to stock but it has been previously tuned so that isn't really an option unfortunately. My truck has a cam in it. Comparing it to a stock file from that same truck, my tune is pretty much the same as far as I can tell.
  1. weird weird weird
    By rodente in forum Cummins 5.9L
    Last Post: February 14th, 2014, 03:38 AM
  2. Runaway throttle and throttle sticking, what tables can affect this?
    By RD in SD in forum E37, E38 & E67 PFI ECM's
    Last Post: May 11th, 2013, 02:20 PM
  3. Trans hits 4th hard with light/no throttle, fine with moderate throttle
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 4th, 2013, 12:10 PM
  4. E38 - Throttle Cut / Throttle Blip
    By Z06-GT3 in forum Lounge
    Last Post: June 14th, 2011, 04:16 AM
  5. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
