Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: O2 voltage logs but doesn't show up in scan and tune chart
  1. #21
    May 2012
    Is there a reason why darcy can see the o2 pid's and others can't?
  2. #22
    Quote Originally Posted by Manuel View Post
    I'm not sure, maybe he's using an older version of the software before the display of sub PIDs was broken.For what its worth, I cannot make the O2S11V or O2S21V display in the charts or in the Data tab page in the current software. I had to make a number of changes to fix the bug to allow the data to display correctly.
    Maybe Darcy can explain how his screen shot was achieved - it could be something that I'm not aware of.
    P.S. The data display has also been fixed to now display like this:
  3. #23
    May 2012
    No problems Paul, I understand that V8 is a work in progress. and I can see the data chart in V7.5 I just glad that you guys helped me out.
    When and where can I find the new update?
    Thanks again.
  4. #24
    Feb 2012
    Correct. I'm still on 8.2.2 build 259
  5. #25
    In small button mode the labels are deliberately not shown, there's not enough room.
    I thought so... I just wanted to make sure it was intentional.
    Thanks.
  1. added lc-1 serial PID but doesn't show up on dashboard
    By Bill00Form in forum FlashScan V2
    Last Post: November 19th, 2011, 10:36 AM
  2. Scan Logs are limited in size or frames
    By Chalky in forum General
    Last Post: July 13th, 2011, 04:49 PM
  3. FUELQ_MAIN_DMA doesn't show up
    By THEFERMANATOR in forum Black Box Logging
    Last Post: September 21st, 2009, 01:53 AM
  4. Scan doesn't work after upgrade
    By ChucksZ06 in forum Gen III V8 Specific
    Last Post: June 2nd, 2009, 03:11 PM
  5. Scan doesn't find PCM - but everything else works ...
    By Garry in forum FlashScan V2 BB Logging
    Last Post: May 17th, 2008, 02:27 AM
