Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: O2 voltage logs but doesn't show up in scan and tune chart
    May 2012
    Default O2 voltage logs but doesn't show up in scan and tune chart
    Need some help please.
    I have been logging for a few weeks now, and really enjoy using the program. So much to learn though.
    The problem I am having is with both narrow band O2 sensors. I can log both sensors mv and information shows up when I open Efiscan V7.5, but when I open the file in scan and tune and try to view it as a chart the information seems to be gone.
    Car is VZ Clubsport, E40 pcm, log file below.
    Thanks.
    May 2012
    Can someone please help.
    They show up on chart...
    you have to first add them to a chart (on corner of chart strip where you want one of the pids, go rightclick->Other PIDS->O2S11-O2SV(mv); on another corner do same for other pid; then do rightclick->Chart Properties and click Save).
    May 2012
    Thanks for your help joecar.
    I get what you are saying. I have included some sreenshots of what happening though. I can get the o2 pid on the chart but no data appears. I must have something configured wrong. Pictures are from the same file that I posted in the first post.
    Hope the pics help explain what's going on.
ID:	18222Click image for larger version.
ID:	18223Click image for larger version.
ID:	18224Click image for larger version.
    Lifetime Member darcy's Avatar
    Feb 2012
    Look at the scale on the chart, it needs to be scaled correctly. In v8, just roll over the pid title and click the little button the looks like to opposing arrows to auto-scale the chart.
    May 2012
    Thanks darcy, that does not seem to work either, if you look at screenshot 2, the is no data in the o2 pid of v8, however (screenshot 4) when the file is opened v7.5 the o2 values are there.
    Feb 2012
    It shows as 0 on the data page in v8 because there are 2 sets of data included in eachd pid - the Voltage & the STFT. v7 lists them separately.
    I can plot both the voltage and the STFT from you log in v8.
    ( If you can't get it displaying on V8 scantool, use the V7 scantool for now (V8 can't do maps yet) )
    I would log HO2S11/21 (if these are available on your OS) rather than O2S11/21.
    May 2012
    This is doing my head in darcy. Is there any chance you can take a screen shot of the data page with my log opened.
    And joecar, I tried looking for a download link of V7 but could not find one.
    Thanks.
    Sorry guys, I worked out how to see the data in 7.5 at least, in the chart, still have no idea why it doesn't show up in V8.
    Thanks for helping again.
    Feb 2012
    All the download links are here: http://www.efilive.com/latest/cat/download-efilive
    Is this what you were looking for?
ID:	18229 Click image for larger version.
  1. added lc-1 serial PID but doesn't show up on dashboard
    By Bill00Form in forum FlashScan V2
    Last Post: November 19th, 2011, 10:36 AM
  2. Scan Logs are limited in size or frames
    By Chalky in forum General
    Last Post: July 13th, 2011, 04:49 PM
  3. FUELQ_MAIN_DMA doesn't show up
    By THEFERMANATOR in forum Black Box Logging
    Last Post: September 21st, 2009, 01:53 AM
  4. Scan doesn't work after upgrade
    By ChucksZ06 in forum Gen III V8 Specific
    Last Post: June 2nd, 2009, 03:11 PM
  5. Scan doesn't find PCM - but everything else works ...
    By Garry in forum FlashScan V2 BB Logging
    Last Post: May 17th, 2008, 02:27 AM
