Results 1 to 6 of 6
Thread: dead e92/ c7 vette, same error as others...
    Sep 2007
    Default dead e92/ c7 vette, same error as others...
    scottcarlsonc7prochargerTUNE.ctzscottcarlsonc7read.ctz
    No start after modifying and flashing... $06FF error please help, on dyno and customer is picking up in AM.
    thanks
    Sorry for the delay, bad timing with everyone having time off over Easter.
    I've fixed your file, maybe too late, but here it is anyway.
    Jul 2003
    What was the fix?
    Removing the CVN correction bytes these tuners are putting in.
    Senior Member VortechC5's Avatar
    Jun 2003
    My E92 was tuned/un-tuned with an Diablo Intune. Am I at risk to run into this CVN problem? If so does the latest release have anything in it to handle this?
    02 C5 Coupe - LS7, TSP 265 LS7 heads, ARH, Z06 cat-back, HREs, 3.73 gears, Wilwood brakes, DeWitts radiator
    15 C7 Z5 1 Coupe - stock for now
    12 Avalanche - tune, Corsa Touring
    Yes it will likely be affected, the latest beta calz files have a fix that users can apply, we can send you a copy for your OS if you let us know what it is so you don't get caught out.
  1. Dead C7 E92. $06FF error
    By undergroundak in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: December 12th, 2014, 03:43 PM
  2. E92 Checksum error !!
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 17th, 2014, 09:33 AM
  3. E92 Not being supported yet?
    By 05gmcsierra in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: October 15th, 2013, 04:13 PM
