Results 1 to 7 of 7
Thread: CAX DTC's
    Nov 2005
    Default CAX DTC's
    Is it feasible to write/use a CAX file to add DTC enablers for controllers that EFILive does not have DTC's mapped for?
    Ive found all of the proper addresses for various DTC's in the .bin, I just would like to add them into EFILive so I can turn the DTC's on/off easily in EFILive vs doing it manually in hex.
    Also...."generally speaking" are DTC's kept at the same addresses in a single controller throughout various operating systems? Or does each OS for a specific controller most likely have different addresses for the DTC's depending on OS? Im talking older Delphi-era stuff, not Bosch.
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Ben I can't think of an older controller we don't have DTC tables for.
    Nothing is ever in the same spot on different OS's, that would make life too easy. You have to think too that GM add and remove DTC's often, we need to generate a list of support DTC's for every OS.
    Nov 2005
    Allison 5-speed and 6-speed controllers.
    12.9s @ 108 mph
    Oh ok, I forgot about them. I don't think we ever looked in to those, I'd be surprised if they were the same as the gas/diesel ECM's, I'm pretty sure Allison did their own software.
    Aug 2013
    Are you trying to figure out lock up issues?
    Nov 2005
    No, I want to do DTC's for the Allison.
    12.9s @ 108 mph
    Aug 2013
    Sorry, I was thinking pid's
  1. Cax Question
    By Chavez91 in forum CAX Files
    Last Post: July 13th, 2017, 06:13 AM
  2. loading in the .cax
    By RADustin in forum CAX Files
    Last Post: June 13th, 2014, 11:03 AM
  3. DTC's from v2 to lap top and cures to DTC's
    By 68problemchild in forum FlashScan V2
    Last Post: October 2nd, 2010, 05:08 AM
  4. E38 and CAX?
    By gmh308 in forum CAX Files
    Last Post: April 28th, 2009, 05:54 PM
  5. cax file?
    By myws6formula in forum CAX Files
    Last Post: December 21st, 2008, 04:00 PM
