2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
Could be that when your FPA drops that low, the part of the table you modified does come into play.
Generally your engine should never operate over in that area...typically any pulse below 40MPa doesnt need to be changed unless your asking it to run on that low FP.
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
The 2 tunes I have one with to much fuel the fuel pressure table is the same and the duty cycle is the same the difference from that tune to the other one is that I lowered PW, cut pilot after 2000rpm, and have no post. I put the other tune into the truck and I am going to data log that and let you know. I hate to run it because its way to smokey, and will probably post the log.
Well it happens with the other tune if I push it hard enough. I guess I should increase fuel pressure down low to possible compensate? Or would increasing main timing help?
Put your DC table back to stock
Les Szmidt
2007 5.9 Dodge Ram
There are tables that simply don't need to be messed with until much later on, and DC table is one of them. As you have found it can be more of a bother than useful
Les Szmidt
2007 5.9 Dodge Ram
So what i probably should do is test those things with a dyno.
