Results 1 to 2 of 2
Thread: LS3 swap, can I tune for LS2-3 knock sensors?
    May 2015
    Default LS3 swap, can I tune for LS2-3 knock sensors?
    I'm considering an upgrading my LS1 with a 411 PCM to an LS3 short block and while I could use LS1 knock sensors I found this: http://racetronix.biz/itemdesc.asp?ic=LS1-KSRH&eq=&Tp= which allows the use of the 2 wire LS2 knock sensors. They say that tuning is required and I'm guessing this would be knock sensor frequency. Do any of you know which tables I would need to change to do this?
    Jul 2003
    There is a lot more than that. Suffice to say it will not work right if you move your knock sensor to the side of the block
  1. Ls2 knock sensors on a gen 3
    By Gregs in forum Gen III V8 Specific
    Last Post: January 13th, 2012, 11:08 AM
  2. Tuning LS2 with LS1 knock sensors.
    By rally1 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 20th, 2009, 02:30 PM
  3. LS2 motor with LS1 knock sensors?
    Last Post: July 9th, 2006, 05:46 PM
  4. LS1 knock sensors in C5 and LS2 block.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 05:15 AM
  5. LS2/LS7 Knock Sensors and LS1/6 PCM
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2005, 10:55 AM
