hey, witch tables do i modyfi to make it run a bit leaner under load
cheers
cheers
Power enrichment table. but MAF and VE should be tuned so commanded AFR will match wideband AFR
+1
You may also have to edit the PE enable parameters.
( but using EQR or Lambda rather than AFR )
