Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Known issues with April 13, 2015 Public Release
    Default Known issues with April 13, 2015 Public Release
    Currently known issues and possible workarounds for the April 13, 2015 Public Release of the EFILive Software and Firmware
    Download the public release software here: http://www.efilive.com/latest/cat/download-efilive
    • Software: V7.5.7.281
    • Software: V8.2.2.275
    • FlashScan/AutoCal firmware: V2.07.82
    Issue 1:
    Workaround:
    None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    Issue 2:
    A change to the EFILive_Explorer software was made to prevent the VIN from being displayed. However, the VIN is being displayed in the OS column, the OS is being displayed in the Stream column and the Stream is not being displayed at all.
    Workaround:
    None. Will be fixed in the next auto-update.
    Issue 3:
    Using the V8 software, VPW based controllers that have a damaged/corrupt seed-key pair (indicated by seed=$0000) may get licensed using a blank serial number instead of the controller's actual serial number.
    Workaround:
    Don't attempt to activate a controller license while the "Assume Lock May Be Faulty" checkbox is checked.
    Issue 4:
    V8 trace filenames use the following naming convention: CCCC_T_YYYYMMDD_HHNNSS.htx
    where:
    • CCC = the controller's code (like E38)
    • T = the type of operation (R=Read, W=Cal-Flash, F=Full-Flash)
    • YYYYMMDD is the date
    • HHNNSS is the time.
    When tracking down problems, trace files are analyzed by EFILive support in date-time order. Usually when customers send trace files to EFILive support, the files' original date-time stamps are lost and it is difficult for EFILive support to sort the files correctly. To allow the files to be easily sorted, the naming convention will be changed to: YYYYMMDD_HHNNSS_T_CCCC.htx
    Workaround:
    None. Will be changed in the next auto-update.
    Issue 5:
    Auto-scaling for V8 Scan Tool charts does not work until at least one chart range selection has been made.
    Workaround:
    Use the mouse to select a range in the charts at least once prior to using the auto-scale feature.
    Or adjust charts' scaling manually, using the MouseWheel and Ctrl+MouseWheel while hovering over the Y-axis of the PID that is to be scaled.
    Issue 6:
    FlashScan V2 external PIDs do not log correctly using V7 pass-thru.
    Workaround:
    Use Black Box logging to capture external PIDs.
    Dec 2005
    What has been changed in the latest release ??
    Thanks for the VIN Help as well
    www.mscservices.net
    These are in from release notes:
    V8:
    Fixed composite PIDs (PIDs that contain sub-PIDs) not displaying their values during Scan Tool playback.
    Optimized USB connection between EFILive_Hapi.exe and FlashScan/AutoCal devices.
    Removed the VIN display column from EFILive Explorer. To restore the VIN display, edit the file \My Documents\EFILive\V8\Config\EFILiveExplorer.ini and add the key ShowVIN=1 into the [Explorer] section.
    V7:
    No change
    Firmware:
    Added support for CSP5 switching when less than 5 tunes are available.
    Also an important note in the release notes is this:
    Your security restriction options on the [Permissions] tab page in the V7.5 Tune Tool software may change during the upgrade to this version of the V7.5 software. Please review those security restriction options and reconfigure them according to your preference.
    Jul 2007
    Sorry, miss-posted....
    Apr 2010
    Has anyone had trouble logging after installing this software?
    I had to start with the preloaded lbz imperial pids and reselect the custom pids from the pid list linked to av1, av2, av3,. If I try to log with the pid list saved from the prior build it displays the message "mode not supported"?
    Quote Originally Posted by dmaxdavid View Post
    When you get the mode not supported error did you only have 1 or 2 ECM PIDs selected? If so that causes EFILive to drop down to "generic scan mode" which is not supported on the LBZ. Try selecting 3-4 ECM PIDs to forec the scan mode to dynamic or higher.
    Lifetime Member zfuller123's Avatar
    Jan 2010
    Can't download the software! Server is broken.... links are broken. Not possible to download the software.
    2005 Crew Cab Dually Duramax
    Big turbos, big injectors, big pumps, crazy heads AND a flux capacitor...
    Best run so far on street tires: 11.14 @ 128.8 mph
    Apr 2011
    Quote Originally Posted by zfuller123 View Post
    Looks like it is working now, Zach.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
    Jan 2010
    Thanks Mike/Rob... it is working now. Haven't checked since I posted figured it'd be a while before we got an answer since they're sleeping :-)
    (not sure who I'm talking to)
    Apr 2011
    This is Mike
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  1. Known issues with March 2015, Release Candidate 1
    Last Post: April 10th, 2015, 10:03 AM
  2. March 2015, EFILive Release Candidate 1
    Last Post: March 20th, 2015, 07:04 PM
  3. Known issues with Feb 14, 2015 release of the EFILive software and firmware.
    Last Post: March 3rd, 2015, 03:03 PM
  4. Known issues with Feb 2015 release of the EFILive software and firmware.
    Last Post: February 9th, 2015, 11:53 AM
  5. Known issues with Jan 2015 release of the EFILive software and firmware.
    Last Post: February 4th, 2015, 06:55 PM
