Results 1 to 7 of 7
Thread: April 2015, EFILive Public Release
    Default April 2015, EFILive Public Release
    April 13 2015, Public Release
    Release Notes:
    This public release is identical to the April 2015 RC2 software. If you have already downloaded and installed the RC2 software then you do not need to download and install this public release.
    If you have an older version of the software installed and you perform a "Check For Updates", you will see a message indicating that t newer version is available but that no patch exists that can be automatically applied. To obtain the latest public release you must download and install both V7 and V8 from here: http://www.efilive.com/latest/cat/download-efilive
    Please read the warnings and imporatant information in the release notes before installing or running the EFILive software.
    Release Notes.
    Known Issues:
    Check for known issues here.
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the "known issues" thread above.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 281
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 275
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.82 (Apr 10, 2015
    To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Senior Member DieselMafialb7's Avatar
    May 2012
    When will we have balance rate pids for the 10-12 6.10-12 6.7 cummins?
    Can these be viewed on the dealer scantool?
    Dec 2005
    Paul, will people running March RC1 be able to open files created with this new release ??
    Or did the .ctz format change up again ??
    www.mscservices.net
    Nov 2005
    The file format change was between public releases. The change was made with the first beta for 10-15 Cummins last November or December.
    Cindy
    Dec 2005
    Were the CAX files accidentally disabled from loading in this newest release, as they loaded up fine with the March RC1 Candidate ?
    www.mscservices.net
    No, nothing has changed with cax files. It may be something in the cax file. Try removing (commenting out) definitions until it loads.
  1. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
  2. Known issues with March 2015, Release Candidate 1
    Last Post: April 10th, 2015, 10:03 AM
  3. March 2015, EFILive Release Candidate 1
    Last Post: March 20th, 2015, 07:04 PM
  4. Known issues with Feb 14, 2015 release of the EFILive software and firmware.
    Last Post: March 3rd, 2015, 03:03 PM
