Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: First fire up stumbles. COS3 80lb 5.3L ls6 cam
    Quote Originally Posted by jay_rich View Post
    Just thought of something. i havent finished putting my trans in. So I havnt hooked up any linkage OR the NEUTRAL SAFETY SWITCH WIRE. Does anyone know if this prevents the pump from suppling fuel after the car has been started. Im almost wondering if the car is firing off the fuel thats in the rail then dying out. Its hard to check the pressure since I have an adjustable regulator that bleeds off as soon as the car is fired. it is a simple fix when I get home. ill just ground the wire for now and see.
    Jay
    No, it does not stop the fuel pump from running.
    Is this what you're seeing, the fuel pump is not running...? When you key-on do you hear the fuel pump prime for 2 seconds...?
    To measure FPR/rail pressure, remove the fuel pump relay and jumper the socket (using a fused jumper wire) so the pump runs; then remove the reference hose and measure rail pressure.
    Did you try this:
    Quote Originally Posted by 240sxpooter View Post
    Also can you keep the car running by giving it gas?
    Aug 2010
    Yes the fuel pump primes on initial key ON and when the PCM is finished tuning.
    When i give the car throttle is dies pretty well instantly. I guess next will be hook the neutral switch up then possible jumper the fuel pump.
    I was having a hell of a time trying to set the rail pressure since the car was just priming for 2 seconds (filling 8an feed and 6an return).
    I will report back later tonight.
    Jay
    Jan 2014
    is the rail holding pressure after it primes?
    Aug 2010
    It is not but its expected with the adjustable regulator. They bleed off the fuel. Its the "summit" version or of the aeromotive 13109.
    Jay
    Aug 2010
    Well didnt do a thing but toss a new tune in it and it fired and ran beautiful. Not sure what i missed on my tune.
    Jay
    Can you compare the old and new tunes (using the compare feature in the tunetool)...
    Aug 2010
    I plan on doing that when I have time this weekend. Its still bothering me what I missed. I basically started with a stock 2002 5.3L file. Did the COS3 and verified everything matched my friends tune for that. VATS/Column Lock was disabled, etc. Unless it was the injector tuning. I did update the voltage offsets to match what i found online.
    Left all the parameters stock but updated the Flow rate (10.079) (43.5psi base 1:1 regulator) then the Voltage offset as following.
    6V=2.811MS
    8V=1.777MS
    10V=1.288MS
    12V=1.017MS
    13V=0.903MS
    14V=0.801MS
    15V=0.721MS
  9. #19
    Dec 2006
    Subscribed 😁😁
    8.7 @ 84 (1/8 mile) bolt-ons
  1. B4001 with 1:1 regulator Siemens 80lb Injectors.
    By jay_rich in forum Gen III V8 Specific
    Last Post: April 7th, 2015, 06:59 AM
  2. Replies: 3
    Last Post: August 29th, 2014, 01:32 PM
  3. shift point for ls6 cam
    By aaronr in forum Gen III V8 Specific
    Last Post: August 16th, 2010, 09:14 AM
  4. Idle speed for LS6 cam
    By aaronr in forum Petrol / Gas
    Last Post: July 7th, 2010, 02:23 AM
  5. newwB has a question 6.0ls1 w/ls6 cam
    By REDDUCK381 in forum Gen III V8 Specific
    Last Post: January 6th, 2008, 12:52 PM
