Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: BBL programming new pid list wont program.
    Aug 2012
    Tried again tonight ,I selected a different file then went back and selected ls1b
    Dragged across the files I wanted and followed the instructions and it worked.
    Tested in car now have wideband and rpm that were missing.
    Very happy now. Thanks for your help anyway joecar.
    Sometimes its just something simple and thought it might be.
    Can you please save the BBx configuration using the [Save] button. Then send attach that saved file to this thread?
    Aug 2012
    This is the options txt file attached was that what you were after?
    I tried the Options.txt file you sent and it appears to work correctly. Can you tell me the following:
    Does the RPM PID show up in the list of PIDs on the FlashScan screen while black box logging? You may need to scroll up/down using the up/down arrow keys to see the RPM PID.
    If it does show up on the screen , does it display the correct value or is it stuck at zero?
    And, after you have logged data for about 5 seconds, stop the loggin (with the Cancel key) and save a trace file (F1 Scan Tool -> F3 Scan?options -> F1 Save Trace File) before disconnecting FlashScan from the vehicle, then send the trace file to me at paul@efilive.com
    Aug 2012
    Just emailed you the trace file,let me know if you got it.
    Rpm and wideband are now showing.
    Was odd I tried multiple times to program it and no change before.
    The trace file that you sent shows everything working normally. Right now I can't explain why it wasn't working for you earlier. If anything odd happens again, post it in this thread and I'll take another look.
    Aug 2012
    Ok I will. Thanks
  1. LLY PID List
    By billybob in forum Duramax LLY
    Last Post: September 26th, 2012, 05:48 PM
  2. NEED HELP WITH PID list
    By restless@westnet.com.au in forum Black Box Logging
    Last Post: May 7th, 2012, 08:41 PM
  3. need help with v2 not read pid list
    By restless@westnet.com.au in forum General
    Last Post: July 7th, 2011, 09:10 AM
  4. Convert Pass Thru Scan PID list to BBL PID list
    By jrh in forum FlashScan V2 BB Logging
    Last Post: July 5th, 2011, 08:09 AM
  5. how to get my pid list to v2?
    By 2004gmc in forum Lounge
    Last Post: May 30th, 2009, 10:52 AM
