Results 1 to 10 of 17
Thread: BBL programming new pid list wont program.
    Aug 2012
    Default BBL programming new pid list wont program.
    Hi
    Iv'e updated to the latest software
    I can log all pid's I want on the laptop no problem.
    Tried programming the v2 for bbl and I cant change the pid's no matter what I try.
    I need rpm and wideband ,tried deleting the pid's i didn't wan't
    Tried programming and it wont change.
    Followed the instructions and no change.
    Never had this issue till the new software was installed need
    some help asap on this one,can't work it out.
    Seems like its just not updating pid's even though it programs.
    Did you update your V2 firmware...?
    Post some screenshots (SHIFT-PrntScr).
    Aug 2012
    Cant work out how to do it.Yes updated to latest firmware.
    EFI_V8PIDS
    ECM.RPM
    ECM.APCYL_M
    ECM.TP
    ECM.KNKRET
    ECM.MAP
    ECM.VSS
    ECM.IAT
    EXT.WO2EQR2
    EXT.WO2EQR1
    EXT.WO2AFR2
    EXT.WO2AFR1
    EXT.WO2LAM2
    EXT.WO2LAM1
    That's the list from selected pids.
    Hit program and it doesn't change to the pid's I want
    where before I upgraded no issues.
    Now I cant log rpm or afr because it wont change.
    Prob doing something wrong but shouldnt be this hard to be honest.
    Quote Originally Posted by VX-SS-383 View Post
    It is crucial that I see what is going on...
    see post #10 here: Hosting-an-Image
    What V8 build version do you have installed...?
    What V2 firmware do you have installed...?
    Did you update the BBx config files...?
    V8 S&T -> Check Firmware, and after updating the firmware, you can see a config update dialog, click Update.
    Aug 2012
Name:	efi live bbx.png
ID:	18255Click image for larger version.
Name:	efi live firmware.png
    On the Program button, click the downarrow and do Format CONFIG filesystem, then when that is finished do Program Selections and Configuration (slower) .
    Aug 2012
    Been trying that and seems to program ok but something is not working.
    Hook it up to the car and select pids and it doesn't show
    this list no rpm and wideband I tried multiple times the other day
    and still made no difference.
    I recorded a log then checked it on my laptop and sure enough
    rpm was blank and wideband,
    No idea why its not programming that pid list.
  1. LLY PID List
    By billybob in forum Duramax LLY
    Last Post: September 26th, 2012, 04:48 PM
  2. NEED HELP WITH PID list
    By restless@westnet.com.au in forum Black Box Logging
    Last Post: May 7th, 2012, 07:41 PM
  3. need help with v2 not read pid list
    By restless@westnet.com.au in forum General
    Last Post: July 7th, 2011, 08:10 AM
  4. Convert Pass Thru Scan PID list to BBL PID list
    By jrh in forum FlashScan V2 BB Logging
    Last Post: July 5th, 2011, 07:09 AM
  5. how to get my pid list to v2?
    By 2004gmc in forum Lounge
    Last Post: May 30th, 2009, 09:52 AM
