Had a quick question regarding cruise control in a custom vehicle swap (standalone).
I know that the ECM (im using LB7/LLY Duramax ECM's) runs diagnostics on the tcc/brake pedal switch to make sure its working properly....IE, a certain number of acceleration and deceleration events has to occur with the TCC/brake switch transitioning appropriately, otherwise the ECM considers the brake switch failed and disables cruise control.
Sometimes its a little more difficult to fit in a "double pole" brake pedal switch (one n/o switch for brake lights, one n/c switch for tcc/brake) in a swap vehicle.
Now, safety issues aside, if one were to disable/not report P0571, would that effectively allow cruise control to keep working with only a brake light signal input? (no tcc/brake input)
Or are there more advanced diagnostics on cruise control "behind the scenes"??
Ben
