Results 1 to 6 of 6
Thread: 2009 6.7 3500 "dpf full message" on overhead
    Apr 2015
    Default 2009 6.7 3500 "dpf full message" on overhead
    I have a 2009 6.7 3500 that I just tuned with efi. I just used stock tune changed nothing other than setting up for delete. truck is now setting dpf full message on overhead. Just wondering if I missed something easy. Thanks
    2009 6.7 stock delete.ctz
    Dec 2013
    Update your V7 EFI live from .262 to the latest and re-check your options and DTCs. There is a lot left behind.
    Apr 2015
    Will do thank you for the help still new at this
    Apr 2009
    thanks
    Chuck Bondurant
    Duramax LMM
    EFI Live tuned -Idaho Rob
    ATS transmission
    Bully Dog - PMT gauges only
    MPI Twins
    40 Over injectors
    FASS Fuel System
    Fabtech 6" - 18" XD Addict Rims
    Apr 2016
    Default dpf full
    Quote Originally Posted by sasdakota View Post
    update your v7 efi live from .262 to the latest and re-check your options and dtcs. There is a lot left behind.
    i have a 2007 c&c 3500. Did the had parts(exhuast,egr) then file mod/ flashed and all seemed fine. A couple weeks later the "dpf ful" message in the overhead came up. Tried to scan the ecm with conventional scanner and no response??? IM RUNNING V8 WITH LATEST UPDATES.
    Jun 2016
    I'm new to this, 07.5 cab chassis 3500 4x4 I just had it deleted and now I keep getting the p1011 code low fuel pressure, truck loses power when light comes on.. Not sure if it's the tuning or it really is a fuel issue, I've been told these cab chassis trucks are a little different on the tuning than regular 6.7 trucks, not sure just what I've been told.. I had a Really Good Shop do it for it but they normally only do Duramax Trucks and have done several dodges with no issues until mine of course! I ordered a fuel rail plug today and changing the fuel filter in the morn.. I didn't mention the truck has 293k flawless miles never been to the dealer one time as soon as the dpf said it was full and see dealer I took it to him the same day.. Any help would be great. Thanks.
  1. Replies: 256
    Last Post: December 7th, 2016, 08:39 AM
  2. Replies: 13
    Last Post: July 1st, 2014, 02:38 PM
  3. "File Sys FULL!" followed by "ERROR: $0520"
    By Sushisan in forum AutoCal
    Last Post: April 24th, 2012, 06:35 AM
  4. DIC reads "clean exhaust filter" DPF DELETED
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 28th, 2008, 05:10 PM
  5. "Service Brake System" message after tune change
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2005, 02:26 AM
