Results 1 to 8 of 8
Thread: 2012 Ram 3500 Stock tune 12351331AN Please?
    Apr 2015
    Default 2012 Ram 3500 Stock tune 12351331AN Please?
    Hello All:
    I am new here, as far as posting goes, been reading for a while thou. I have 2012 Ram 3500 I am working on. I am trying to locate the stock tune for it, 12351331AN. The files available on depositfiles site incorrectly shows 12350331AN as the tune for a 2012 3500. I have loaded both the 2500 and 3500 tunes into V7.5 , and they both show as the same. Can anyone help point me to a place where I can get the 12351331AN stock tune file? Please and TNX .
    crdth.
    Apr 2015
    12350331AN can be used interchangeably for 12351331AN
    They are identical with different names.
    Apr 2015
    TNX for the reply. How does one go about doing a compare in V7.5 to check for any differences between files? Further, how were these files obtained if they cannot be read from an ecm?
    TNX
    crdth
    Apr 2015
    Quote Originally Posted by crdth View Post
    TNX
    crdth
    Ctrl F12 or the double red arrow.
    I dont know what files you have nor know how they were obtained.
    Apr 2015
    Sorry, I guess I should be more specific. I found the compare function, but TNX as well. The files located at depositfiles site are efilive reads of stock controllers. I am just wondering how they came to exist if we do NOT have the ability to read a calibration out of a 2010 or newer CM2200A cummins ECM.The file all have a ctz file extension, so they must originate with efilive, or not?
    TNX in advance.
    crdth.
    Senior Member KhakiCummins's Avatar
    Sep 2011
    I believe the files are stock files from Tech Authority used with Chryslers flash tool and someone has converted them to a .ctz format.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Apr 2015
    Quote Originally Posted by KhakiCummins View Post
    Hello Duane:
    TNX for the reply. I think that is most likely the source also. SO, back to my original request, could any one help me find a copy of 12351331AN for a 2012 3500 50 state auto 4x4. I would like to run some file compares, with some other calibrations to be sure.
    TNX in advance
    crdth
    Apr 2015
    The binary of the two files is exactly the same. There is nothing to compare.
  1. 2012 Ram stock tune
    By turk88 in forum Cummins 6.7L
    Last Post: April 16th, 2015, 03:03 PM
  2. Stock tuning file for 2012 6.7
    By dodgeram5-92500 in forum Diesel
    Last Post: January 8th, 2015, 08:50 AM
  3. I need an 01 3500 cab and chassis tune file
    By Madspeed in forum Duramax LB7
    Last Post: November 4th, 2013, 08:13 AM
  4. Replies: 7
    Last Post: September 17th, 2012, 02:00 AM
  5. 2012 5.3 silverado knocking with stock tune
    By TravRMK in forum Gen IV V8 Specific
    Last Post: February 15th, 2012, 06:21 AM
