Results 1 to 5 of 5
Thread: B9021 access and refinement
    Feb 2015
    Default B9021 access and refinement
    Hi guys,
    I've fixed my P1518/P1514 issues from another thread but I want to start this thread for the sake of b9021.
    I've searched this forum and read about the .cax files that are suggested. Every application I've seen suggested has been applied to <2002 MY PCM's. I have a 2003 pcm currently running COS 3150003. Am I missing an obvious or obscure selection from this COS to manipulate B9021.
    In another thread, I read about B9021 being applied across all COS after? Is this true?
    I have read some references that B4003 or B4004 was actually the B9021 table in disguise.
    Like many that have stumbled along before me with the struggles of getting the idle PW below 2.2ms at close throttle. I know that the transitional table has a lot to do with adding to that PW output.
    If you look at my log, when I hold rpms at 2000, the PW goes below 2 ms and the engine actually sounds pretty good at that point. I have pretty bad plug fouling right now with a rough idle and my wideband AFR is indicating about 11.5~12. (no i haven't hooked it up to the flashscan yet.
    I'm a high school autoshop teacher and this project has been an interesting one to share with my kids as they see the improvements with each little change. I keep telling them that you should only do one change at a time to see if that change actually did any good or not. Your feedback to me is also helping the kids in my labs as I share this learning experience with all of them.
    Thanks again - Jason
    See attached tun and logs:Log_0031.efiLog_0032.efiLS1 _ COS3150003v4_fuelPSIADJ_lambda1_STFTon_0002.ctz
    Hi Jason,
    See this thread for all the known B9021 cax files: need-B9021-for-01250003
    take note: each COS has a base OEM OS, meaning that you can rename the OEM OS to the COS's id.
    ( each OS has B9021 at a different address; someone had to reverse engineer a PCM binary image to discover where B9021 is located at in the OS for that PCM )
    This is not necessarily true, altho the effect may be the same (now you've got me thinking, I'll have to research this out).
    Hey, good job with the autoshop class, and good advice (one change at a time)
    Oct 2006
    B4003, B4004 are a completely different parameter, but will have a similar result if set higher than B9021. For instance, if the B4003 minimum pulsewidth value is hit, the value in B4004 will be used in the fuelling calculation. This is why these parameters must be set lower than or equal to B9021.
    The Tremor at AIR
    Hi Jason,
    BTW, some miscellaneous comments on your ctz file:
    - B3616 (PE Enable): this is too restrictive; set it same as 2002 F-car (12212156).
    - B3618 (PE EQR): if you're done tuning (MAF and VE tables are correct), then this may be too rich for NA; for boost it is ok.
    - B4001 (IFR): slope is ok for un-referenced FPR; but for boost, it is recommended to swap to referenced FPR (for which IFR will be flat).
    - transmission WOT parameters are upside-down (downshift MPH should be below upshift MPH).
    - D0960,1,2 (Throttle Kickdown): set these to 100% all across to allow PT tables to control shifts; more info: When-throttle-kickdown-is-not-set-at-100
  1. 12592618 b9021 CAX file
    By 5.7ute in forum CAX Files
    Last Post: January 19th, 2023, 02:57 PM
  2. need B9021 for 01250003
    By BLK02WS6 in forum CAX Files
    Last Post: December 10th, 2019, 12:04 PM
  3. b9021 help
    By danny68ss in forum General (Petrol, Gas, Ethanol)
    Last Post: January 14th, 2015, 10:49 PM
  4. is B9021 available for OS 12587603?
    Last Post: November 4th, 2011, 04:39 AM
  5. b9021
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 01:22 PM
