Results 1 to 4 of 4
Thread: Innovate LC-2 pids
    Junior Member eacostad's Avatar
    Jan 2010
    Default Innovate LC-2 pids
    Just bought an Innovate LC-2 and im a little confused on how to set it up. Im using a Null Modem to connect it to my V2 and im not sure where im supposed to hook up the brown and yellow spliced wires too. All I can find is LC1 wideband info other than the sticky on top of this page. Also Do i just choose the Innovate (LC1,LM1,LM2) on my flashcan device settings? thanks
    2007.5 Silverado 2500HD Duramax, EfiLive Tuned, Airdog 150, MBRP dpf&cat delete exhaust
    Brown and Yellow wires are the analog outputs from the LC-2, leave these unconnected (tape them up to insulate them).
    You simply need only the null modem serial comms connection.
    Yes, choose Innovate in the V2 wideband config settings.
    Also, in the V2 Device Settings, under Logging, checkmark to automatically log the digital/serial pids.
    The pids you will log are EXT.WO2xxx.
    Jan 2010
    thanks for the quick response, just he information I was looking for. Thank you
    No worries.
    Correction:
  1. the innovate LM-2
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2009, 01:22 AM
  2. Innovate and MAP.
    By tgeers in forum General (Petrol, Gas, Ethanol)
    Last Post: August 11th, 2006, 10:06 PM
  3. Anyone using Innovate LC-1 WBO2s?
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2006, 01:50 PM
  4. Innovate LM-1 Voltages.
    By curtbriggs in forum General
    Last Post: September 4th, 2005, 02:15 PM
  5. Innovate LC-1
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2005, 05:35 AM
Tags for this Thread
