Results 1 to 10 of 18
Thread: why does it die when coming to a stop?
    Nov 2011
    Default why does it die when coming to a stop?
    title fairly self-explanatory. Decent size cam in an ls11. Automatic. Stall converter, aluminum flexplate.
    Just trying to get thoughts on why this happens so i can investigate it in the tune.
    Nov 2011
    Zeroed out the direct airflow correction table. Seems to have helped. I think the corrections were compounding the issue, either correcting too slow or correcting down too much.
    Still experimenting.
    Which columns in B4515 did you zero...?
    Nov 2011
    All of them for now.
    Nov 2011
    Tried zeroing spark idle corrections first. Problem was unchanged. So I reversed that and did direct airflow.
    Apr 2008
    please post file and datalog as well as mods.
    Regards,
    Odd Boy
    +1 please post files.
    Jan 2014
    sounds like you need more base airflow. this is what my truck was doing before I added air flow. I did RAFIG then added a bit to it.
    I did have an issue afterwards where the truck was learned down too far so I think it's best to make sure the values to add learned airflow are larger than subtracting. this way it learns up faster than it learns down.
    Nov 2011
    I'll look into that. Logs coming soon, been catching up with work.
    Jan 2014
    turn rolling idle off or at least raise the speed that is considered 0 or whatever. then log coming to a stop.
    you will probably see RPM just die off while MAP slowly rises to atmosphere.
    are you electric throttle or cable?
  1. ***Need help with idle surging while coming to a stop please***
    By WICKEDOWESIX in forum Gen III V8 Specific
    Last Post: December 30th, 2009, 08:38 AM
  2. small surge when coming to stop
    By whackem04 in forum Duramax LLY
    Last Post: December 28th, 2009, 09:50 AM
  3. Idle surge coming to a stop
    By slowhawk in forum Custom Operating Systems
    Last Post: March 18th, 2008, 02:41 PM
  4. Surging when coming to a stop
    By 12secformula in forum Gen III V8 Specific
    Last Post: December 18th, 2006, 02:01 PM
  5. Surging when coming to a stop
    Last Post: October 16th, 2006, 09:03 AM
