Is anyone else aware of a work around for the newer limitations with TIS off board programming detection? Cannot program some modules now with the bosch flasher-pro.
Custom Tuning Services
Flashing in the truck/car is your only workaround, oh and it has to be the correct truck/car to do it as well.
All modules Tony? This is a mess.
What model year vehicles did they start imposing these limitations?
2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison12.9s @ 108 mph
many thanks to Ross and Paul
I think all CAN based vehicles.
You do have every right to complain to them as I did, but it will fall on deaf ears.
LBZ still works on the bench...Ill try LMM in a bit.
Ran into this on newer ECM's. Considering building something with an arduino and can shield super ghetto, just to properly respond to the polls TIS is making and let it proceed.
Two things need to change with TIS. Remember you are paying for this service, you have every right to complain to them.
1 - The off board programming check needs to go, I'm not sure what GM are trying to achieve with this.
2 - The override option to reprogram a controller even when the same software is detected needs to be added, how else can people return an ECM to stock?
FWIW the support for TIS seems to be handled by Hewlett Packard
