Here's the problem
Fan 1 is coming on at all times and engine temps and I can't figure out why. Temp is set to 205F. Even though the relay is powered by ignition power the fans are not on with key on and engine off. Only when engine is actually running. Ect can be 80F and fan is still on.
If I go to engine control section in scan tool and enable fan 1 and fan 2 control I can shut off fan 1.
My only thoughts are it has something to do with AC? G0911? AC is built into the harness and fuse box but is not yet hooked up.
