Results 1 to 8 of 8
Thread: Wheres My Timing At?
    Default Wheres My Timing At?
    We Are Tuning A 01 Z06 Vette With A Custom Op (202003) and are having a little issue. The Car Is a fully built 382 LS6 with a F1-C Procharger making about 15 psi. Between 170-180 kpa I lose timing, 3 degrees at first and then about 1 1/2 after that. I have checked TQ mangment, enabled forced octane scaler, all air temp and coolant temp modifiers and everything else I could think of. What am I missing? Can I log some pids to figure it out?
    P.S On a side note when changing to a custom os on a car with a auto trans and no maf how does the trans know when to shift ?
    Thanks, Bill
    www.ForceFedPerformance.com
    Aug 2004
    Bill, ill be back in town on wednesday, give me a call and ill explain some things for you. Jes
    Member VYSSLS1's Avatar
    Dec 2005
    the transmission will shift on the vehicle speed sensor, and wot rpm.
    Dec 2005
    also check what you have entered in B6210 and B6212 and A0010
    i hope this helps.
    We are not seeing any knock....its just really weird. We are no strangers to tunning the ls1 motor, we have just been using ls1 edit for the past 3 years and just switched over to efilive in the past 8 months. At 5000-6000 it just pulls timing for no aperent reason other then it hates me...lol.
    Its making 600 HP At 5000 at 10 psi. I just want to finish tunning this thing and get it out of my hair.
    Thanks, Bill
    www.Forcefedperformance.com
    Bill, there is some specific spark PID's you could log.
    GM.EST_TRQ_DMA
    GM.EST_KRB_DMA
    First is spark retard due to calculated torque limits being reached.
    The second is of course Burst Knock, sometimes when running with no maf (I assume that combo is) burst knock can false trigger, as VYSSLS1 suggested, B6210 is the answer to that.
    Make sure you turn that forced octane scaler off when done!!
    Thanks for your help i will try those but have 2 questions.
    1. I was under the impression the burst knock was only on tip in?
    2. i have rasied the torque to the max setting, if the computer is still pulling timing because of the torque how do i get around it?
    P.S Yes there no maf
    Thanks, Bill
    Dec 2005
    Quote Originally Posted by Forcefedperformance
    Thanks, Bill
    hey bill, no need to get on your high horse, you asked for help, and i thought id help, little things can be overlooked when getting fustrated, i hope this info helps.
    anyway, how did you go, did you get it sorted out.
  1. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    Last Post: November 17th, 2009, 01:15 AM
  2. Ok.....wheres my problem
    By Forcefedperformance in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 20th, 2009, 11:32 AM
  3. Timing the LMM
    Last Post: March 25th, 2009, 01:04 PM
  4. Wheres the spark?
    By shane in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 18th, 2008, 12:59 AM
  5. where is my timing?
    By Cablebandit in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 7th, 2007, 07:40 AM
