I'm going to be doing the STS kit and running motron 60# injectors ....my stock pump drops about ~2-3psi at WOT. would upgrading the fuel pump keep that steady instead of varying?...stock pump is seeing 58psi peak
should I run the stock fuel pump and the 60#ers or upgrade the pump also?
