Results 1 to 7 of 7
Thread: Need a calc_pids.txt file for a (PLX serial wideband) to OLSD Auto-VE Please !!!
    Senior Member RandyWS6's Avatar
    Jan 2005
    Default Need a calc_pids.txt file for a (PLX serial wideband) to OLSD Auto-VE Please !!!
    Im doing OLSD tuning on my 2000 WS6 with a LS3 442cid.stroker,I have done some tuning with my V1 with PLX analog WB, witch worked fine for years . But I upgraded to the V2 and modified the PLX for serial ,but I need a calc_pids.txt for my Serial-WB PLX .I can read the Serial WB on my laptop. But need a MAP so I can AUTO-VE tune. Ive tried building a calc_pids. but with no luck. And been on here for two day reading on Serial WB set up and found a lot of info, but not on the PLX Serial WB, accept on how to mod the serial to the PLX-WB, witch I have done . But had no luck on how to build a calc_pids. to MAP it . Will I need to build something like the analog (BO101) Main-VE BEN.map. I do have the PLX (analog) to the V2 and can Auto-VE with it in need be. I'm not to smart with the new V2 setup yet. But I could build a custom cacl_pids. if I knew what to do. Can any body with a Serial PLX-WB help me please.
    2000 WS6 TransAm-M6 LS3 forged 422 cid. 4L80 FMVB ,4:22 Ford 9"-35 spline axles
    2014 C7 3LT-Z51 Corvette Stingray M7 , A&A Supercharger , Kooks 1-7/8" long tubes & X Pipe 615 rwhp & 560 rwtq
    http://community.webshots.com/album/259987907DcztOG
    Lifetime Member darcy's Avatar
    Feb 2012
    Use the calc_pids file from the Calc.VET thread, first post. Calc.VET: correcting MAF and calculating VE (in single log)
    Since you're using a serial input, it doesn't matter what type of wideband you have if the v2 is reading what it's saying.
    From that calc pids, you can just use CALC.WO2BEN (which is = {GM.EQIVRATIO}*{EXT.WO2LAM1})
    Jan 2005
    Yes I all ready done that and works fine . but the problem that im having is that the CALC.BEN_LAM1 was not matching with the commanded 14.70AFR in my (B3647) The PLX controller is 14.70 AFR and my (B3601) 14.63 AFR and the {GM.EQIVRATIO}*{EXT.WO2LAM1}) is showing 14.81 AFR
    The PLX User Guide is in the Attached File.
    I found this on here, (B3601) Expression, and it matches what im seeing in my log files . It said it for Analog and im Serial , but it matches perfect. Do I put the 14.81AFR in to my (B3601) to replace the 14.63 ????
    This was in EXCEL but had to convert it into text
    PLX WB
    Maximum Voltage 5.00
    Minimum Voltage 0.00 {B3601} Expression
    Voltage Range 5.00 {EXT.AD} * 1.9896 + 9.948
    PLX WB AFR Expression
    Maximum AFR 20.00 {EXT.AD} * 2.0000 + 10.000
    PLX WB
    Minimum AFR 10.00 Lambda Expression
    AFR Range 10.00 {EXT.AD} * 0.1360 + 0.680
    Maximum Lambda 1.360
    Minimum Lambda 0.680
    Lambda Range 0.680
    {B3601} To Volts 14.63 2.353
    AFR To Volts 14.70 2.350
    Lambda To Volts 1.00 2.353
    Volts To AFR 2.443 14.89
    Volts To Lambda 2.444 1.01
    Volts To {B3601} 2.444 14.81
    The thing is to how do I build a (Serial MAP) that I can AUTO_VE, or (Copy with Labels) & (Past and Multiply with labels) into my (B0101) Main VE table.
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    # See sae_generic.txt for more information on the *UNITS section
    *UNITS
    #Code System Abbr Description
    PSI Imperial PSI "Pounds Per Square Inch"
    None None "" "No units"
    # Add slot definitions here
    # See sae_generic.txt for more information on "SLOT" formats
    #Units Low High Fmt Expression
    *CLC-00-001
    PSI 0.00 100.00 .1 "({GM.EGRS}*25)-12.5"
    *CLC-00-031
    factor 0.5 1.5 0.3 "{GM.EQIVRATIO} / {EXT.WO2EQR1}"
    *CLC-00-032
    factor 0.5 1.5 0.3 "{GM.EQIVRATIO} / {EXT.WO2EQR2}"
    *CLC-00-041
    factor 0.5 1.5 0.3 "{GM.EQIVRATIO} * {EXT.WO2LAM1}"
    *CLC-00-042
    factor 0.5 1.5 0.3 "{GM.EQIVRATIO} * {EXT.WO2LAM2}"
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code PRN SLOT Units System Description
    CALC.FP F001 CLC-00-001 PSI Fuel "Fuel Pressure"
    CALC.BEN_EQR1 F031 CLC-00-031 factor WO2-Serial "BEN Serial Wideband 1 (EQR)"
    CALC.BEN_EQR2 F032 CLC-00-032 factor WO2-Serial "BEN Serial Wideband 2 (EQR)"
    CALC.BEN_LAM1 F041 CLC-00-041 factor WO2-Serial "BEN Serial Wideband 1 (LAM)"
    CALC.BEN_LAM2 F042 CLC-00-042 factor WO2-Serial "BEN Serial Wideband 2 (LAM)"
    Quote Originally Posted by RandyWS6 View Post
    {EXT.WO2LAM1} is the what the PLX reports (in text form) regardless of the analog PLX-conversion/V2-deconversion being done...
    are you saying that EXT.WO2LAM1 reports 14.81...?
    What is the stoich AFR of the fuel you're running...?
    ( I would ignore AFR and concentrate on BEN calculated from EQR and/or Lambda )
    ( i.e. forget about CALC.BEN_LAM1, and use CALC.WO2BEN instead )
    Jan 2005
    OK ill try CALC.WO2BEN, How do I build a (Serial MAP BO101 Main VE) that I need to (Copy with Labels) & (Past and Multiply with Labels) to correct the VE tables
    (are you saying that EXT.WO2LAM1 reports 14.81...?
    No , Im sorry here is what I seen in my log. with 93oct. Fuel
    WO2AFR1 14.74
    WO2BEN = .996 (GM.EQIVRATIO / EXT.WO2EQR1)
    WO2BEN1= .995 (GM.EQIVRATIO * EXT.WO2LAM1)
    WO2EQR1= 1.000
    WO2LAM1= 1.000
    WO2AFR1 14.81
    WO2BEN = 1.000 (GM.EQIVRATIO / EXT.WO2EQR1)
    WO2BEN1= 1.000 (GM.EQIVRATIO * EXT.WO2LAM1)
    WO2EQR1= .996
    WO2LAM1= 1.005
    The Calc.VET thread shows you how to create a map that matches your VE table...
    see post #1 Section I item 4 here: Calc-VET-correcting-MAF-and-calculating-VE-%28in-single-log%29
    WO2AFR1 14.74
    WO2EQR1= 1.000
    WO2LAM1= 1.000
    WO2AFR1 14.81
    WO2EQR1= .996
    WO2LAM1= 1.005
    For each of those what was the value of GM.EQIVRATIO...?
    ( in both cases GM.EQIVRATIO would have been 0.996... can you see this in your tune file...? )
    Post your tune file, your log file, and your calc_pids.txt file.
  1. help with calc_pids.txt file
    By GSXRTURBO1 in forum Black Box Logging
    Last Post: September 30th, 2013, 06:06 AM
  2. CALC.VET calc_pids.txt for serial LC-1?
    By Rich Z in forum Gen III V8 Specific
    Last Post: January 21st, 2013, 09:02 AM
  3. Help with calc_pids.txt file...willing to paypal money
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: October 5th, 2010, 02:59 PM
  4. Auto ve and plx wideband?
    By mvnvltn in forum Gen IV V8 Specific
    Last Post: December 31st, 2008, 07:20 AM
