Results 1 to 3 of 3
Thread: LS1B PCM locked with a custom key
    May 2012
    Default LS1B PCM locked with a custom key
    working on a car with a egine swap 5.3L TH350.. car isnt working as it should, when i want to install the new tune it wont let me, it says it is locked with a custom key, someone should locked it to protect their work.. how can i install the new tune..?? i know i can with techII but i dont have one here or near here
    Apr 2008
    Hi,
    If it is locked you won't be able to unlock it even with TechII. There is a way but:
    it is locked to protect others' work
    the way I do is very headache and doesn't deserve the effort than buying a used one from the Junk yard...
    Regards,
    Odd Boy
    May 2012
    Quote Originally Posted by odd boy View Post
    Hi,
    Thanks,, Yes i tried with Tech2 and couldnt flash it, got a used one and tuned the car.. thank you very much
  1. LS1B PCM locked
    By C5 Pete in forum Gen IV V8 Specific
    Last Post: July 23rd, 2014, 06:38 AM
  2. Code $0537: Controller is locked with a custom key
    By 9mmkungfu in forum Duramax LB7
    Last Post: May 1st, 2014, 10:21 AM
  3. "controller locked with custom key" DEAD ECM
    By DURAtotheMAX in forum Duramax LLY
    Last Post: May 14th, 2012, 01:25 PM
  4. Vat relink??? Says "Locked with custom key"
    Last Post: September 6th, 2005, 03:15 AM
