Results 1 to 7 of 7
Thread: e67 commanded fuel going lean
    Apr 2006
    Default e67 commanded fuel going lean
    all ol tables set to 1 and pe at .8 floor the car it goes to 11.74 afr then starts to trail commanding lean?
    ive got to be missing a table somewhere
    attached is the log where right in the begining you can see a wot pull
    E67 dyno meth.ctzLog_0018.efi
    Apr 2006
    car has meth and iat is moved out of maf so the iat sees the meth, dont know if thats the issue
    Apr 2008
    أHi,
    To get quick help, you need to post tuning file and car mods...
    I looked at the datalog, and assuming that you're talking about WOT. I have the following comments as of now:
    - wot was few seconds only, when the pedal released it went back to normal lambda. frame (267 - 290)
    Regards,
    Odd Boy
    Can you also log EXT.WO2LAM1 and EXT.WO2EQR1.
    Apr 2006
    The tune file was loaded. The ctz file. I will get the ext pids logged. And yes wot the commanded goes to 11.74 then still at wot the target trails lean. Then when you get out of throttle it returns to 14.68
    Car is a heads cam pulleys longtubes Ctsv. Stock shortblock automatic.
    May 2010
    Subsribed as i have same problem in 2 cars for the first time without any reasons
    EFILive Tuner
    Aug 2013
    I can see where it commands leaner... and there's also a drop in RPM at that point, which makes me think it's got something to do with a gear shift or TCC engaging.
  1. Commanded Fuel when Cranking
    By gpr in forum Gen III V8 Specific
    Last Post: March 11th, 2013, 11:33 AM
  2. Commanded Fuel Pressure
    By Compcowboy in forum Cummins 6.7L
    Last Post: January 5th, 2012, 01:04 PM
  3. AFR not what Commanded- lean no matter what i change
    By nonnieselman in forum Gen III V8 Specific
    Last Post: April 13th, 2009, 04:52 PM
  4. Commanded AFR goes lean at high MAP value
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2009, 04:24 PM
  5. Lean spikes commanded vs actual AFR
    By billyjo in forum Custom Operating Systems
    Last Post: January 24th, 2008, 05:58 PM
