Results 1 to 7 of 7
Thread: Opinion
    Nov 2012
    Default Opinion
    I want you guys to take a look at this tune and let me know what you think. This is for a full built 2.6 puller. I didn't write the tune but I am concerned about the timing. Not really the timing but the fuel split as it has as much as 57% fuel being injected before TDC. What do you think about that high of percentage going in before TDC?
    Nov 2010
    5-things...
    1. How many RPM is this "Full Built" truck supposed to turn?
    2. Does the tune writer understand "Sensor Saturation"?
    3. The timing your concerned about is fine
    4. Does the tune writer understand the total timing they are calling for with regards to "Post Timing" still being active in the upper rpm range?
    5. There are still a couple limiters that are going to hinder your fueling in the upper RPM areas
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Nov 2010
    And FWIW...on my pull tune with my Street Driven 2.6...I run near 80% BTDC timing...
    Les Szmidt
    2007 5.9 Dodge Ram
    Nov 2012
    #1 it will turn 5000 but not under load.
    #2 not sure he does I'm not sure I do either, can you please explain?
    #4 I noticed that he still had some post active, can you please comment on the results of doing so?
    #5 can you tell us what limiters were missed in this tune?
    Are you saying that in some areas you have 80% fuel split going in BTDC?
    Nov 2010
    1. There is zero timing control in your tune for anything over 3500rpm...that needs to be fixed.
    2. There is no point in commanding 200MPa when the stock sensor is maxed at 180MPa.
    3. Running a post event at the rpm your looking to run, will be chasing the piston down and will likely be damaging.
    4. There is a PID limiter in the rpm table that needs to be raised
    5. Yes, on my truck I run near 80%BTDC in certain areas
    Les Szmidt
    2007 5.9 Dodge Ram
    Dec 2013
    Quote Originally Posted by 2007 5.9 View Post
    5-things...
    One thing I noticed is that post is "0" by pulse not qty. Odd to kill pilot by qty but post by pulse...
    I'm not a sled puller though, can't offer too much assistance in the 5000rpm realm.
    Nov 2010
    Quote Originally Posted by SASDakota View Post
    Correct and unless its killed by pulse, mm3 and timing..the multipliers will still generate a value and a post event will occur.
    Les Szmidt
    2007 5.9 Dodge Ram
  1. Performance Magazine Opinion
    By Vickie in forum General
    Last Post: December 10th, 2013, 03:02 PM
  2. opinion on injector choice
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2009, 02:07 AM
  3. 4L60E Experts/Need Your Opinion On Tune?
    By turboolds in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 28th, 2008, 08:53 AM
  4. Need VE Tuning Opinion
    By Dennis93TA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 2nd, 2007, 05:48 AM
  5. Need the opinion of others ;)
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: April 19th, 2006, 08:01 AM
