Results 1 to 5 of 5
Thread: fuel pressure dtc causing confusion
    Mar 2014
    Default fuel pressure dtc causing confusion
    I have an employees truck setting a p0191 in a 2011 lml. Upon discovery of code I recommended removing regulator for inspection per pip4949d of si. After inspecting metal debris was apparent. After discussing info it was decided that a cp3 conversion was the proper solution to his 200k cp4 failure. A replacement cp3 fleece conversion with an upgraded pump was performed. After installing a tune with fleece's flow vs current table applied and vehicle started all seemed to be well. Pressure matched desired and seemed to run great until we returned from test drive and truck set p0191 again at idle, the only time it has ever set it. I have deleted code for time being, but am curious to what exactly this code's importance is and what problem may or may not still be causing. I really hope we did not immediately wrongly accuse the pump for failure even though it seems highly likely given the metal debris found on the regulator screen, but seems that maybe previous tuning may be the cause or it's a separate problem with the tuning that has always been there, any insight to this issue would be greatly appreciated
    Mar 2014
    I would also like to note that to my knowledge dtc was not present prior to tuning, it wasn't an immediate result but a new one in the following weeks
    Mar 2014
    anyone seen this?
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    It is not uncommon to see that code with a CP3 swap.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    Mar 2014
    this code was present prior to swap, but I've been recently informed that the 2nd regulator is most likely cause, not a huge issue just demining that problem was apparently not in pump pressure at all.
  1. fuel trims causing a VERY lean condition.
    By rumblebox in forum Gen III V8 Specific
    Last Post: November 26th, 2013, 09:34 AM
  2. can I log fuel pressure with my glowShift fuel pressure gauge?
    By ryans1000 in forum External A/D inputs
    Last Post: August 16th, 2011, 01:35 AM
  3. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  4. vx ss fuel pressure????
    By HINDZY in forum Gen III V8 Specific
    Last Post: October 12th, 2007, 02:27 PM
  5. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
Tags for this Thread
