Results 1 to 10 of 13
Thread: 2015 lml trans limp
    Apr 2015
    Question 2015 lml trans limp
    Hay guys im looking for some insight here, Just finished up a truck and its having an issue. I have a V2. Tuned ECM with one of PPEI's tunes (eco_tow 30HP). Runs great, but cust. was pulling a 40' float and trans set a P0732- 2nd gear incorrect ratio. Talked to tuner and he wanted me to clear code and complete Fastlearn. Sent Cust. out with trailer and problem hasn't returned. Tuners rep suggested this was internal trans, however I don't feel this is the case (26,00 miles and not doing this until now). No less I was wondering if anyone had seem any issues like this. Hoping it just needs to learn adapts.....
    BTW I have ZERO exp writing tunes, Im wet and green behind the ears here. So im likely to ask some stupid questions.
    Sep 2015
    I just had with same problem on a 15 LML with 25,000 mi. It keeps limping in 5th gear. Im new to righting lml tunes so wondering if something in the file would cause this or is the trans really week? ive already tried to to trans relearn.
    Jan 2015
    same problem here. 2 trucks that have been tuned with PPEI and had same P0732 code when towing heavy. I dont know what the problem would be I didnt bother to call PPEI. I just told customer its time for trans upgrade. One truck pulls a 5th wheel and the other pulls a boat. He never had that issue before tuning. wondering if trans just cant hold 30hp added in second gear.
    08 LMM CC Dually
    Canada
    Lifetime Member Road's Avatar
    Feb 2015
    Common issue with 15+. These tranny run very low line pressure, you can purchase trans tuning to increase line pressure or purchase a solid plug to install with the pressure control solenoid. Always recommend new filters too.
    Jun 2019
    I have a 2015.5 lml, started having the same issue with it. Iv done quite a bit of research with Allison and GM.It has a T87 tcm witch Chevrolet decided to take over the electronics side of Allison in 2015. Turns out GM started putting there on valve body on witch has a spacer and gasket between the valve body, it has twice as many holes in it to release the line pressure faster takes away the hard Allison shift, that we who pull know is needed to keep the trans from slipping. My builder is working with GM now to try and come up with a solution for my issue.
    Feb 2015
    Quote Originally Posted by Nathan Turner View Post
    Might suggest to your builder to start putting a line pressure modifier in on all his builds. Brief description is here:
    https://whitehorsetuning.com/#!/2011...egory=29609073
    May be more info on Dirty Hooker Diesel website.
    Jun 2019
    He did, and when he tested the line pressure after the install it was still at factory setting. Almost like the tcm noticed the high pressure and opened the solenoid.
    Feb 2015
    Solenoid is bypassed it can't control pressure. We have test them and trans tuning in house and everyone else in the game has too. It works. We were all having issues with this at one time but since the line pressure mods, problems have been fixed.....
    Jun 2019
    Did the test truck have a t87?
    Feb 2015
    Yeap
  1. Trans limp mode ?
    By tinman in forum Cummins 5.9L
    Last Post: August 4th, 2013, 01:53 AM
  2. Turning off a Trans Limp? Is it possible?
    By Mitco39 in forum Allison 5 & 6 Speed
    Last Post: August 24th, 2012, 04:49 AM
  3. Limp(s) and "invisible" limp
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 21st, 2011, 12:40 AM
  4. Is this LIMP?
    By Boost in forum Allison 5 & 6 Speed
    Last Post: September 21st, 2010, 11:53 AM
