Results 1 to 10 of 10
Thread: Tach Pull-up Enable B5402
    Dec 2010
    Default Tach Pull-up Enable B5402
    Hey guys, have a 1995 S10 that I swapped with an LM4 out of a trailblazer. The tachometer in the s10 doesn't show rpm with the engine running. I have heard you have to have a "pull up wire" with a resistor to boost the signal into the tachometer. I don't have that wire put in yet.
    Going thru the tune, I noticed this Tach pull-up enable feature under System->Tach->B5402.
    Currently it is set to yes, and my tachometer doesn't work. Do I need to change this to "No" before I wire in the Pull Up wire ? Just curious as to what its function is, and to get my dash to read RPM's.
    Let me know, thanks!y
    Dec 2010
ID:	18321Click image for larger version.
    Are you sure the Tacho in the S10 is just a 0 - 12V pulse input?
    Dec 2010
    That I would not know for certainty. Best way to check?
    I don't know sorry, someone who knows that car well might have figured it out.
    Nov 2013
    I have the pullup resistor installed on my Autometer Tach in my cutlass. My tune has always had B5402 switched to "yes". My tach only worked properly when I added the resistor.
    Sep 2010
    What resistor did you add Jetmech, and did you you just add it into the tacho wire on the way to the tacho???
    Dec 2014
    Quote Originally Posted by Hooter View Post
    1k ohm resistor in parallel with tach signal and ignition.
    Dec 2010
    I went ahead and put a pull up wire in, and the tach is now functional. This is the diagram I used.
    http://lt1swap.com/pictures/tach_circuit_fix.jpg
    Sep 2010
    Thanks guys, I will try this on a Nissan patrol LS1 swap
  1. Tach pull up resistor only some E67 cals ??
    By 95wagon in forum E37, E38 & E67 PFI ECM's
    Last Post: December 20th, 2014, 06:09 PM
  2. Tuning the tach 68 camaro tic toc tach
    By 68problemchild in forum FlashScan V2
    Last Post: December 11th, 2010, 03:20 PM
  3. E-38 Tach output
    By MSURacing in forum Gen IV V8 Specific
    Last Post: February 10th, 2009, 06:45 AM
  4. Speedo and Tach OFF
    By 00RAPTOR in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2007, 06:51 AM
  5. Calibrating the TACH for V8 HOW TO?
    By Jdperk-86elco in forum General (Petrol, Gas, Ethanol)
    Last Post: May 23rd, 2006, 03:22 PM
