Results 1 to 3 of 3
Thread: 2013 LML Fuel Rail Pressure Drop
    Feb 2015
    Default 2013 LML Fuel Rail Pressure Drop
    Hey Guys,
    Wanted to see if any of you have run into this before. While on the dyno yesterday we discovered that my fuel rail pressure drops off dramatically once I hit about 2550 RPM's. I'm not throwing a code currently but have set the P0087 low rail pressure code in the past (pre lift pump install). Yesterday Rail pressure dropped to 6K and still no SES light or code. Truck pulls hard until that point and then obviously falls off once the pressure drops.
    I have a 2013 GMC LML/Allison 27K miles on the OD with the following mods. EFI Tuned- full delete, EGR bypass, down pipe back exhaust, Air Dogg 4G-165, Sumped 60 Gallon tank, Stock fuel filter by-pass. S&B Air Intake.
    Any help would be appreciated.
    Thanks,
    Dec 2005
    Weak Cp4 ?
    Too much fuel being commanded.
    Something off in the tune.
    That would be my top three guesses.
    Good luck
    www.mscservices.net
    Lifetime Member Road's Avatar
    Feb 2015
    Pull the regulator out of the pump and check for metal debris. Too bad you voided your warranty.
  1. Fuel Rail Pressure Issues
    By WisconsinHick1 in forum Duramax LB7
    Last Post: July 26th, 2012, 08:39 AM
  2. LBZ-Odd Rail Pressure Drop
    Last Post: May 7th, 2010, 11:55 AM
  3. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  4. fuel rail pressure
    By drdarthinvader in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 07:17 PM
  5. Fuel Rail Pressure
    By Dave Lewis in forum Duramax LB7
    Last Post: July 30th, 2006, 02:54 PM
