Results 1 to 2 of 2
Thread: autocal help
    May 2015
    Default autocal help
    I need help setting my autocal up so that i can read the tcm file to send to my tuner. i have used them on other cars and it was in the read 2 slot. this autocal only has the ecm in read one and all the rest are blank. i just installed a new trans in my 2013 ctsv and need to figure this out so i can get it running again. Thanks for any help.
    Jan 2015
    You should be able to configure your AutoCal in your v8 on your computer. Once plugged in and your v8 open select BBx tab on the left side of your screen. Select your tcm in scan and tune, save in each then select quick setup and program. This will remove the other ECM/tcm combos that are currently configured on your autocal. But you can always add them back. Or select those at the same time (while in the scan and tune tabs).
    Your tuner should be able to walk you thru this.
  1. Autocal
    By boogie in forum AutoCal
    Last Post: June 4th, 2012, 11:12 PM
  2. AutoCal?
    By Highlander in forum FlashScan V2
    Last Post: December 18th, 2008, 07:41 AM
  3. Autocal
    By Alvin in forum Lounge
    Last Post: August 1st, 2007, 01:55 PM
