Results 1 to 8 of 8
Thread: DUAL O2s capabilities
    Apr 2015
    Default DUAL O2s capabilities
    I would like to run the FAST Air/fuel meter part number 170634 but they do not sell a dual sensor setup. Can EFI LIVE V2 read two different AFR inputs. I want the gauge on the pillar. This will give me two gauges I know but its the only way I can have a gauges and external data log to my V2. If anyone knows anything different plz advise. I want dual sensor because I want to run long tubes and dual cutouts.
    EFILive FlashScan can read upto 4 analog AFR inputs (if this is what you're asking)...
    Post a link to the FAST 170634 user manual pdf.
    Apr 2015
    What about digital inputs? No clear user manual available. Sorry.
    From what I see of the 170634, I don't see any serial outputs...
    Quote Originally Posted by j.w.jones@live.com View Post
    What about digital inputs? ...
    What do you want to input into V2...?
    V2 has two 0-12V discrete/switched signal inputs (i.e. V2 sees either high (12V) or low (0V) on these).
    Does the FAST have a serial comms output...?
    ( post the user manual pdf )
    Apr 2015
    What are serial outputs?
    serial comms (i.e. RS-232 and similar protocols)... sometimes called digital outputs.
  1. Do these O2s look bad too you?
    By bigblock69 in forum Gen III V8 Specific
    Last Post: June 5th, 2012, 01:18 PM
  2. Does the 12200411 PCM have Tow/Haul Capabilities?
    By A Low Dime in forum Vortec V6/V8 Specific
    Last Post: September 22nd, 2010, 03:13 PM
  3. V2 Capabilities out of the box?
    By Cougar281 in forum FlashScan V2
    Last Post: January 16th, 2007, 12:35 AM
  4. Tuning without o2s question
    By tuff in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2005, 03:12 PM
