Results 1 to 4 of 4
Thread: Frustrated nOOb.. New Cam
    Jul 2011
    Default Frustrated nOOb.. New Cam
    I installed a new cam and cannot get it to idle correctly without throwing a P0106. I have tried to do the Swingtan VVE Dial in, but I cannot get it to idle long enough to drive and log it. I have added air into the idle table, etc. I've got help here and there but nothing I can really go by.
    I attached the before cam tune (tuneb4cam), current tune (GXP_Isky....), the Swingtan VE tune that I cannot get to idle, and a log with the "current tune."
    Any help would be greatly appreciated.
    wb log.efi
    GXP Isky_DW_0006.ctz
    TuneB4Cam.ctz
    SwingtanVE.ctz
    Jul 2007
    Any reason why C0805 and C0806 are set the way they are?
    P0106 is a MAP sensor performance issue, however I get the feeling that the rational tests will combine both the MAP and MAF settings and correlate between the two. So setting C0805 and C0806 to the wrong values can throw either a MAP or MAF code.
    Have you tried settings these tables to something more like this?
    • C0805:
      LABELS Maximum Airflow Change (Grams/Sec)
      TPS % Value
      5.00 34
      10.00 30
      15.00 32
      20.00 40
      25.00 50
      30.00 60
      35.00 70
      40.00 70
      45.00 70
    • C0806:
      LABELS Maximum MAP Change (kPa)
      TPS % Value
      5.00 63
      10.00 45
      15.00 40
      20.00 37
      25.00 37
      30.00 33
      35.00 33
      40.00 33
      45.00 33
    Jul 2011
    I think they were like that stock, I captured a stock file from TuneFileDepot when I first started messing with it and it shows to be about the same. I will try this and report back.
    2009 Chevrolet CSV R8 Sedan Automatic LS3 6.2 Litre (24249179).tun
    Stock values may not necessarily be the correct values.
  1. Replies: 9
    Last Post: November 22nd, 2010, 02:57 PM
  2. A little frustrated...Bootloader Rejected?!
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 2nd, 2010, 12:03 PM
  3. Confused and Frustrated
    By petestoy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 22nd, 2008, 03:26 PM
  4. getting pretty frustrated again
    By BACKinBLACK in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2006, 02:40 PM
  5. Frustrated, confused and out $240
    Last Post: July 6th, 2006, 11:54 AM
