HOWEVER, IF you want to use WIDEBAND ONLY in Calc.VET, you can tailor Calc.VET to do this...
there are several ways to do this (choose just one method, not all):
EITHER:
1. in CLC-00-032, replace {GM.EQIVRATIO}=1 with 0:
Code:
*CLC-00-032
factor 0 4 .0 "0"
and continue to use CALC.SELBEN to correct the MAF.
OR:
2. in CLC-00-220, replace {CALC.CL} with 0:
Code:
*CLC-00-220
factor 0.5 1.5 .4 "iff(0, {CALC.LTFTBEN}, {CALC.WO2BEN})"
OR:
3. in CLC-00-305 (and in CLC-00-315 for Calc.MAFT), replace {CALC.SELBEN} with {CALC.WO2BEN}:
Code:
*CLC-00-305
% 0.0 100.0 .2 "{CALC.WO2BEN}*{CALC.VEN.%}"
VE 0.0 2.468 .4 "{CALC.WO2BEN}*{CALC.VEN.VE}"
*CLC-00-315
gps 0.0 400.0 .1 "{CALC.WO2BEN}*{CALC.MAFN.gps}"
and use CALC.WO2BEN to correct the MAF.
