Results 1 to 10 of 19
Thread: LBZ conversion starts then dies
    Feb 2015
    Default LBZ conversion starts then dies
    Hi All EFILive users.
    I require some help with a starting issue I have with my LBZ conversion into a Aussie Nissan Patrol. ( Yes another Patrol & Aussie).
    I have got the engine running but have got an issue with having to wait at least 12 seconds or more before the engine fire up properly & can drive away. It is like there is a extended wait to start feature there.
    The engine will fire when the key is started straight away but then die's. It's as though it fires on rail pressure then die's. Try to start again and it is very sluggish to fire & takes some time before you can drive it.
    Set up of the engine is as follows.
    -Only has engine & trans Controllers.
    -Wiring designed by myself.
    -Have disabled the Vats (I think)
    -Disable EGR (I think)
    - Haven't use the ECM relay circuit to power up the ECM, have used the Nissan powering system
    This is the first Conversion I have done & if anyone is willing to release info that could help me with this issue, I will be much appreciated.
    If you want to PM info the will be appreciated also.
    Regards Gards
    If VATS wasn't disabled I would suggest it would not even run at all.
    I don't know what your issue might be but have you checked if there is any DTC's getting stored?
    Feb 2015
    I have checked & there is some DTC's stored.
    At present, I don't have them with me. The car is 250km away at the moment.
    I do know though once I have the car running, I can clear all the codes & nothing else shows up.
    Go & start the engine again & DTC's come up again.
    I do have to work through the codes when I down at the car next week & will take note of what they are.
    I have been reading some forums that have got a symptom close to what I have & it leads to the ECM relay circuit. This is one relay that I DO NOT have wired up. I am going to try with the relay in the harness & see how it goes.
    Thank you for the help.
    Feb 2015
    Hi guys
    Finally got the DTC's
    As Follows
    Diagnostic Trouble Codes
    P2510 ECM/PCM Power Relay Sense Circuit Range/Performance EPA Pending
    U0101 Lost Communication With TCM EPA Pending
    P0045 Turbo/Super Charger Boost Control Solenoid Circuit EPA Pending
    P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low EPA Pending
    P0113 Intake Air Temperature (IAT) Sensor Circuit High EPA Pending
    P0700 Transmission Control Module (TCM) Requested MIL Illumination EPA Pending
    P0646 A/C Clutch Relay Control Circuit Low P
    P0532 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage P
    P0102 Mass Air Flow (MAF) Sensor Circuit Low P
    P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage H
    P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage H
    P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low MH
    P0463 Fuel Level Sensor 1 Circuit High Voltage P
    U0106 Lost Communication With Glow Plug Control Module P
    U0101 Lost Communication With TCM MH
    P0700 Transmission Control Module (TCM) Requested MIL Illumination H
    P0381 Wait to Start Lamp Control Circuit PHC
    P2510 ECM/PCM Power Relay Sense Circuit Range/Performance MPHC
    P0522 Engine Oil Pressure (EOP) Sensor/Switch Circuit Low Voltage H
    P0827 Up and Down Shift Switch Circuit Low PHC
    If anyone can make heads or tails of these, it would be much appreciated.
    Once I have the engine running, I can clear all the codes & the engine light goes out & car drives normally.
    I have a feeling it may have something to do with the ECM power relay sense circuit, but I don't know what to do to fix this Code.
    I have temp wired in a relay using the ECM relay wire pin 19 C2 & still have no luck.
    The only other thing that may be an issue is that the O ign power should be live in Acc/Run/Start on the key,
    I have only got power to this in run/start.
    Could this cause any prob's do you think?
    Will post up conclusion of what I find if get there.
    Kind Regards
    Gards
    Regards Gards
    Mar 2009
    You have a problem with the igntion 1 relay I believe it is. The ECM commands this relay on, and if it doesn't you will get those ECM/PCM power relay sense circuit codes. And if everything doesn't power up in sequence, you will also get the communication error codes.
    Feb 2015
    Thanks Ferm
    Mate I temp wired in the ECM relay but didn't have it switching the power to Ign1 (used what I had wire with the Patrol) & this didn't change anything.
    I have been looking at the Ign0 power & how it is live in Acc/Run/ start. With the harness, this is not wired this way. The power is live only when in Run/Start.
    C
    Do you think this may have something to do with the power up sequence of the ECM.
    The other thing is, on another forum, a guy has found info saying that the code could also be affecting the power down sequence of the ECM.
    I think I might have to look at the way I am powering up the ECM again.
    I really do thank all of those who are helping with ideas. I do know that we will conquer this problem.
    I know it is hard for you guys in the US. not know how the wiring is on the car in Aus.
    Thank you again
    Regards Gards
    Regards Gards
    Mar 2009
    I doubt having the IGN0 not on during acc is affecting anything. The only way that could be a problem was if it was in a truck and the BCM was controlling things. It still sounds like a problem with the power up and down sequence as I know the DURABURB guys ran into this early on with LBZ swaps.
    Feb 2015
    Tongue in cheek, is there any way that I may be able to get a diagram on how the Duraburbs have wired in the power.
    Also, do you know what the sequence is for power up & down the ECM for the LBZ.
    I am going to have a closer look at the power supply for the ECM & see if there is anything that I may have over looked.
    Thank you Ferm
    You are being very helpfully in trying to nut out this problem.
    Gards
    Regards Gards
    Feb 2015
    Sorry just another quick question.
    Could there be a fault in the ECM that may be causing these codes.?
    With the DTC's active, can I change the ECM with another 1 to see if the DTC's are still there or could this damage the next ECM?
    Regards Gards
    Nov 2007
    I ran into a similar problem with a 2009 lmm/4l85e swap out of an express van to a 03 Hummer H2. The glow plug controller, and TCM communicate with the ECM through the EBCM. I haven't driven it yet as I'm currently in the wiring harness modification stage, and not sure if I,m going to run the ABS, and SRS system with the Hummer control system or the van's system. I temporarily jumped the communication wire's at the EBCM connector and corrected the loss of communication codes. I'm not sure if the LBZ runs the communication network through the ABS module or not, but after I jumped the pins at the connector throttle response was much crisper.
    Sam
  1. Loaded tune and truck starts then dies
    By dsltnr in forum Cummins 5.9L
    Last Post: February 10th, 2014, 07:16 PM
  2. Starts but then dies
    By Johnnydangerously in forum Gen III V8 Specific
    Last Post: June 12th, 2012, 03:03 PM
  3. Starts, reduced power, and then dies...
    By snax in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 27th, 2010, 10:57 AM
  4. Loaded Custom OS: 03Z06..starts/dies after 1 sec
    By Earl H in forum Custom Operating Systems
    Last Post: May 7th, 2007, 08:55 AM
  5. starts for 1 sec and then dies
    By Cablebandit in forum Custom Operating Systems
    Last Post: April 8th, 2007, 12:32 PM
