Results 1 to 3 of 3
Thread: Setting up to pass smog...check this out
    Jul 2007
    Default Setting up to pass smog...check this out
    Do these graphics indicate any problems? I thought I had an EGR system. Do the non supported parameters appear correct?
    When I do a code read I get zero codes.
    I just removed my EGR plate and flashed it back stock for smog. Anything else I should look for? I'm aware its a code inspection, visual, and 3 sec smoke test.
    Log attached also. Towards end of log was WOT.
    EDIT: I still have switch wired, but is well hidden. Does it affect the stock setup?
    Log file from stock tune no egr plate
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    The "Not Supported" tests have to match the BAR's database for your VIN of what is supported and not supported.
    Member mpdtune's Avatar
    Jul 2013
    Quote Originally Posted by TFZ_Z06 View Post
    Get a generic code reader that supports a monitor check and use that. They're like $150 or so. Most of them have a "State OBD Check" option. You can't disable monitors in EFILive so they should all be there and say they are complete. At a minimum all 98-07 diesels will have a Misfire and Component monitor, so the Scan tool showing those not supported makes me think it's not actually reading them.
  1. Failed Smog... tune?
    By ferocity02 in forum Gen III V8 Specific
    Last Post: March 27th, 2013, 01:03 PM
  2. Tuning for Smog Test
    Last Post: February 13th, 2013, 05:39 AM
  3. Need Tune to Pass Smog Testing in Colorado
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: March 13th, 2012, 03:19 PM
  4. Passed CA SMOG!
    By LastCall in forum Gen III V8 Specific
    Last Post: May 27th, 2010, 06:48 AM
  5. Smog Inspection
    By Rich in forum General (Petrol, Gas, Ethanol)
    Last Post: March 25th, 2008, 07:01 AM
