High guys. The kids and I have been working on the shop project for a bit and I finally have new hotside hardware installed with no leaks.
Previous running sessions were with the stock throttle body open to atmosphere.
Now I have the intercooler plumbing installed and now I have a P0068 P0106 setting only at idle.
I've researched this bugger a bit and I don't have a firm grasp of which two tables need to correlate.
Is P0068 setting from a symptom of the engine runnnig rough at idle and causing the MAP to read too high?
The engine smoothes right out at 1500-3000 rpm free revving but still bogs and has heavy timing retard when put into gear. I know timing tables need some tweaking from what I read of the late great weatherman's posts.
I'm just trying to avoid doing the blind redneck tweaks and changes that seem to only be a bandaid. ie. setting p0068 to only set at >8000 rpm.
Here is my current tune and logs:
LS1B_2005_COS3_12592618_V3a_0006.ctz
Log_0035.efi
Log_0036.efi
Again, this communities' insight and enthusiasm has not gone unnoticed. This project is for my automotive kids I'm teaching right now. It's extracurricular but I've already noticed one of my kids actually looking at Kettering University for the ability to play and get paid at the same time!.
