Results 1 to 10 of 10
Thread: No throttle after os swap
    Jan 2011
    Default No throttle after os swap
    Hello there,
    lets start with telling what i have:
    2006 6.0 with turbo and a th350 for now.
    i did a full reflash on the ecm to get it down to a 2003 OS.
    i did the whole os swap thing, ecm took it all. i know the tps and tac module from 2003 vs 2006 are different so i swapped them out for the 2003 metal pedal ones.
    if i turn the ignition on, throttle body cycles and responds to the pedal, as soon as i try to start engine, nothing. pedal is dead and the engine stalls. the t body is not attempting to keep it idling.
    i increased C6101 by 50% at first, no go so i did another 50%. still nothing.
    anyone has seen this before?
    thanks for your time,
    Matt
    Jan 2011
    i have confirmed the wiring of the ecm plugs between years and they are the same
    It would be setting a DTC, did you check them?
    Jan 2011
    I just did, no codes. I tried another tac module and pedal from a running 04
    Thanks,
    Matt Derks
    www.derkscustomcars.com
    Jan 2011
    I will hook up my tech2 and see what I can find out
    Thanks,
    Matt Derks
    Jan 2011
    i flashed the 2006 ecm back to the base 2003 os and tune and she fired right up. i must have missed something
    Feb 2006
    no. this is something that has happened to me a few times with e38 ecu's.
    something seems to get corrupt in the tune files. so u need to flash back in a working file/calibration. then do a compare and copy all your tables back again.
    Jan 2011
    thanks, yes i did reflash the stock tune, ran fine, reflashed the custom os and its all working. still working on the map sensor. it seems to fall on its face when stepping on it. but customers vehicles first. maybe on the weekend
    Dec 2014
    I'm having what sounds like the same issue. I'm running a 5.3 with turbo, TH400, COS5, and cable throttle body. It will idle but when I give it any throttle it just dies. Did you happen to find the issue with yours?
    Jan 2011
    Some setting is the diagnostic side . Joe car explained it all
    Thanks,
    Matt Derks
  1. Runaway throttle and throttle sticking, what tables can affect this?
    By RD in SD in forum E37, E38 & E67 PFI ECM's
    Last Post: May 11th, 2013, 02:20 PM
  2. Trans hits 4th hard with light/no throttle, fine with moderate throttle
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 4th, 2013, 12:10 PM
  3. 06 tbss e40 hanging throttle after ls2 car tb swap
    By b18cls1 in forum Gen IV V8 Specific
    Last Post: December 24th, 2011, 10:17 AM
  4. Throttle Body Swap
    By L31Sleeper in forum Conversions / Aftermarket Parts
    Last Post: June 10th, 2011, 12:36 PM
  5. off throttle dying after tranny swap...
    By Superado in forum Gen III V8 Specific
    Last Post: October 14th, 2008, 03:00 PM
