Gents,
i have been looking all over to find a list of boost capable map sensors, i know i can buy a new one for a cobalt ss but i have a couple here.
can anyone tell me if they support boost?
PN 16249939
pn 09359409
pn 12594942
Gents,
PN 16249939
pn 09359409
pn 12594942
well i found one of a duramax, pn 16235939, however i cant get it to read over 105, i have a regulator hooked up and monitor map.sae, scaler is set at 460, it reads low now but no matter what value i put in there, 105 kpa is max. 2006 ecm with 03 os. any one have any suggestions?
See if GM.MAP is available for your ECM, from memory SAE.MAP is clipped to 105kPa.
gm.map is not a valid pid with my ecm.
i tried looking at a duramax tune and see if i could find the settings but they are not in there
I use Ac delco 2131631. If its going in an ls1 intake- I had to trim one side of the mounting ears off and mount it so connector faces drivers side(backwards). But it works like a champ.
Thx. I just got a 2 bar of a cobalt ss. Works like a charm
