Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Unrecognised PCM 2011 HSV Clubsport
    Feb 2011
    Default Unrecognised PCM 2011 HSV Clubsport
    I haven't had this happen before but before I go putting a different tune file in the car I wanted to see if anyone else has had the same issue and if someone can help resolve.
    I have updated V7.5 and V8, FS has been updated and I have run the update patches. I also read the ECU via V8 to ensure it wasn't a bug.
    OS 01250232
    Calibration 12639269
    Being a HSV, I can't reflash the ECU via TDS with Tech 2 but there is a calibration on tune file depot which is 12629270 for 2011 HSV?
    Here's the message i'm getting
Name:	Screen capture.jpg
    Nov 2007
    Post the file. I think it's a HP tuners COS
    just do a full write with that 270 os. you'll be ok.
    Feb 2011
    Added to original post.
    Feb 2011
    It all makes sense now.
    That's what I will do
    looking at the tune, it doesn't look much different than a standard tune, apart from the hpt ve stuff replacing the factory vve
    Dec 2017
    Hi, I also have OS 01250233 but my Calibration is 12647990. Can I also use that file as i am recieving the same unrecognised pcm message.Thanks in advance.
    ( BTW: you can capture screenshots directly on your PC, see SHIFT-PRTSCR... also see getgreenshot.org )
    Easiest thing to do is go to.
    https://tis2web.service.gm.com/tis2web/
    punch in the vin and go through to the ecu and it will tell you factory os/cals it should be.
    then look / request a factory tune for that os/cal.
    Software Description
    Main Software Calibration Module 12653249
    System Calibration Module 92265567
    Fuel Calibration Module 92265405
    Speed Calibration Module 92263123
    Engine Diag. Calibration Module 92265402
    Engine Calibration Module 92265398
    Dec 2017
    Thanks for that,it just so happens that you have exactly the cals listed that i need by the looks of it. I notice the main software cal & speed cal file on my ecu are different to the ones that came up on that website you linked me to.
  1. Anyone know of any tunig issues with 2011 HSV LS3
    By dazzak75 in forum Gen IV V8 Specific
    Last Post: January 28th, 2012, 01:35 PM
  2. 2011 HSV E3 tuning
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: September 30th, 2010, 02:25 PM
  3. Unrecognised PCM
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 9th, 2007, 07:34 AM
  4. 04 HSV Clubsport and 02 switch point question
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 11:47 AM
  5. HSV Clubsport/R8 Manual Tune (Stock)
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: December 13th, 2005, 09:50 AM
