Results 1 to 5 of 5
Thread: E92 pickup 2015
    Sep 2011
    Default E92 pickup 2015
    hi everybody,
    I am working on 2015 pickup sierra and I am facing unusual issue .
    I keep trying to open engine rev limit but the ECM hold the rpm on 5800 even on driving/parking/neutral .
    Anybody have idea what's going on ?
    I will attach the file below
    hp.450, it looks like there was an issue with the definition of that RPM limiter table, if you can please download the attachment in this post and put in to this folder.
    C:\Program Files (x86)\EFILive\V7.5\Calibrations\E92
    Because it was not changing the correct table when you first did this I would suggest starting again from the stock tune.
    Please note, that .calz file is designed to work with the software release from May 1st 2015
    http://www.efilive.com/latest/cat/do...e-may-01-2015/
    Apologies for the error.
    Regards,
    Sep 2011
    Thank you so much , I will update my devise then i will feed you back with the resolve
    Sep 2011
    GMPX,
    We update and copy your attachment to the folder and try to tune but still we are facing the same issue . Any other way to solve this issue ?
    Did the table look different when you reopened the file?
    This is what it looked like for us, we also found no other instance of a 5,800 RPM limit.
  1. maffless on a drive by wire 2004 chevy pickup 6.0
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: September 17th, 2011, 06:21 AM
  2. VSS Signal style/type ? (pickup question)
    By J 98ta in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 03:40 PM
  3. Replumbing the PCV pickup point
    By joecar in forum Tips and tricks
    Last Post: March 1st, 2006, 04:07 PM
