Results 1 to 3 of 3
Thread: LS3 Starts and immediately dies
    May 2009
    Default LS3 Starts and immediately dies
    I have an LS3 Rod that has an inconsistent start then immediately die condition. Intermittent because sometimes at random it will start and run fine.
    I have changed crank sensor as well as checked the powers and grounds. All of the sensors seem sane. As the intake system isn't conducive to a properly functioning MAF I have tuned it in Speed Density. Attached is the tune file. Any thoughts? Thanks!
    ERod_LS3_11April2015_SD_0005.tun
    Apr 2006
    i had an issue similar with the gmpp controller and it was not failing the maf when it started and died immediately
    May 2009
    The solution is in Swingtan's tutorial, thanks Swingtan:
    Home
    Forum
    General information
    Tutorials
    E38 VVE Setup Guide
    Basically if the MAF is failed in the cal and also the signal wire pulled it defaults to a very low mass flow and reduces injection to such a small value it won't keep running. Set DTC Type P0101 P0102 P0103 to C Non Emissions.
  1. LBZ conversion starts then dies
    By Troy Gards in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: 2 Weeks Ago, 03:26 PM
  2. Loaded tune and truck starts then dies
    By dsltnr in forum Cummins 5.9L
    Last Post: February 10th, 2014, 06:16 PM
  3. Starts but then dies
    By Johnnydangerously in forum Gen III V8 Specific
    Last Post: June 12th, 2012, 02:03 PM
  4. Starts, reduced power, and then dies...
    By snax in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 27th, 2010, 09:57 AM
  5. starts for 1 sec and then dies
    By Cablebandit in forum Custom Operating Systems
    Last Post: April 8th, 2007, 11:32 AM
