Results 1 to 10 of 20
Thread: Bank to Bank Injector Base Pulswidth difference in open loop
    Oct 2005
    Default Bank to Bank Injector Base Pulswidth difference in open loop
    Has anyone else seen this in their logs? Or are your Bank 1/Bank 2 identical? I am seeing up to 2msec bank to bank difference in OLSD.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Oct 2005
    I found an old log on here from back when I was using my Roadrunner PCM and different injectors .... the IBPW values were always identical in that log. That was before the RR went wonky and started doing odd things with fuel and timing. Maybe I have a third bad PCM? (The factory one died during a flash.) Going through a lot of licenses.
    Looking at some other logs I posted on here in 2011(https://forum.efilive.com/showthread...ght=roadrunner), it appears that the IBPW values have been non-identical at least since I've had the ID1000 injectors. So this has occurred with 2 different PCMs.
    Do you have a spare PCM to try on...?
    Oct 2005
    Yes, I have a spare I can license. Will be testing this tomorrow.
    Oct 2005
    Did not bother to license another PCM today because the IBPW values were identical for a change. Only changes to the tune were some VE tweaks.
    Quote Originally Posted by DrX View Post
    Ok, so it is not the PCM...
    but somehow it was calculating differently across banks, and now you threatened it with replacement so it is now conforming...
    Do you have any NBO2 connected (front or rear) even if not being used...?
    Oct 2005
    Fronts are still connected. I have thought about unplugging them.
    I'm wondering this: even tho CL/LTFT/trimming is disabled, does PCM find some reason to read the NBO2's (does it jump into some special mode)...?
    Oct 2005
    Well, that didn't last....back to different fueling on each bank with Bank 1 richer than Bank 2 even though the Bank 1 IBPW is usually lower than Bank 2. At WOT with Bank 2 at commanded AFR of 10.84(NGK AFX), Bank 1 is 9's(LC1). Same thing with heat soaked idle... If Bank 1 is at commanded, Bank 2 is way lean or vice versa. Going to have to find some better injectors anyway because the duty cycle is maxed out on the ID 1000s if I shift at higher than stock shift points. I am also exceeding 512g/s on my 50% scaled tune.
    You will see in the log that I had to back off the throttle on launch because the transbrake wouldn't release. So, bad day at the track, but at least I collected some data.
    Here's the video that syncs with this log file. Stock shift points on this pass. If I run 6500 RPM shift points it shifts at 6800-7000 and crosses the line at the top of second.
    Oct 2005
    Dropped off the injectors to be tested today.
    100-200 miles and a few passes on these plugs. All on VP110.
  1. E67 Injector Bank pulswidth Value issue.
    By railheadwrench in forum E37, E38 & E67 PFI ECM's
    Last Post: November 15th, 2011, 07:55 AM
  2. Replies: 3
    Last Post: June 16th, 2010, 10:40 AM
  3. Bank 1 to Bank 2 Injector Pulse time
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: June 10th, 2010, 06:33 AM
  4. Ignition timing issue,bank to bank
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: December 5th, 2009, 12:38 PM
  5. bank to bank variance in open loop!?
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: July 21st, 2006, 04:38 AM
