Results 1 to 5 of 5
Thread: Difference between Direct and Learned Idle Airflow
    Mar 2009
    Default Difference between Direct and Learned Idle Airflow
    I'm trying to better understand direct and learned airflow. Tables and their effect on STIT and LTIT.
    When they are active?
    How do the trims effect them?
    Differences?
    Impact on final idle air flow?
    You have to read the descriptions of the various idle tables/parameters to link the concepts together...
    ( at this point I'm not sure )
    Mar 2009
    Anyone else?
    How about learned airflow correction VS direct airflow correction?
    The fields are the same, except direct airflow correction has two additional columns for AC on/off for a total of 6.
    Mar 2009
    So I think I figured most of this out, see below:
    B4515 - Direct Airflow IS Proportional idle - makes direct airflow adjustment based on error over B4509.
    B4514 - Learned Airflow IS Integral idle - updates learned airflow based on error over B4508. This value is added to desired airflow based on conditions.
    B4512 - Filtered RPM Airflow Correction IS Derivative. Looks at rate of change as errors approaches 0.
    If anyone has anything to add in, feel free.
    Quote Originally Posted by LastCall View Post
    Good job
    after you posted this thread (you can see my knowledge level of it in post #2, in between the parentheses), I started reading and re-readingall the descriptions for the idle tables/parameters, it did make my head spin in 3 planes...
    I really appreciate you sharing your conclusions, thanks I will sticky this thread.
  1. Desired Idle Airflow
    By ferocity02 in forum Gen III V8 Specific
    Last Post: March 26th, 2013, 11:06 AM
  2. E38 idle airflow
    By KenB in forum E37, E38 & E67 PFI ECM's
    Last Post: May 28th, 2012, 11:20 PM
  3. Startup Airflow and Startup Friction Airflow whats the difference
    By carneb in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2006, 07:59 AM
  4. idle adjustments and airflow
    By heavyfoot in forum General (Petrol, Gas, Ethanol)
    Last Post: June 23rd, 2006, 11:35 AM
  5. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 10:07 AM
