E38 08 corvette LS7 cam227/243 115 stock heads milled .020
It will not stay running when in SD mode.
I setup the sd open loop as per https://forum.efilive.com/showthread...VE-Setup-Guide
got the up to temp on the stock tune, then installed sd one, removed the wire on the maf
I even tried multiplying the B8101 by 2 times thinking it was to learn without success.
Any ideas?
Also attached is the car running with the stock tune with the only modification is idle speed and timing
